Results 1 to 10 of 15
Thread: Building New PC (please help)
    Jun 2001
    Boise, ID (USA)
    Question Building New PC (please help)
    Ok, Anyone want to point out the error of my ways?
    I am going to be ordering some new parts for my computer...
    Asus model TUSL2-C Motherboard
    Pentium 3 1133 MHZ TUALATIN 512K L2 cache Processor
    Corsair 256 Meg PC150 Memory
    Dual Western Digital Caviar 7200 rmp 40Gig hd's
    PCI Raid Controller
    ATI All in wonder Radeon 7500 (Already have)
    Any suggustions? (no intel vs amd arguments please)
    Thanks,
    Mike
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    Wait - are you building this for home use or car use? Cause if you're building this for your car, then you just backed over a kitten All of this hardware is too valuable to make building a car-PC worthwhile. You'd be better off spending $100 combined for a Celly 650, mobo & 256mb PC133 RAM. Plus running RAID in your car is a frivilous idea - you'll just break 2 drives instead of only one.
    As for home PC - well hell, anything goes these days. My only posing to you is this: What do you need a RAID for? What information do you need to keep on hand immediately that's too important for you to backup onto CD? (mind you, RAID won't stop an mp3-killing virus... only regular backups will)
    If you're using RAID for performance, then you might be better off getting more RAM first. However that really raises bigger problems (using RAID for performance) because then I'd have to ask why you're not going with a DDR SDRAM mobo or RDRAM mobo, and a P4 1.4 or greater.
    And on that note, Why not go for a P4 1.4 & mobo? Fry's has been having a P4 1.4 & mobo bundle for $150 every weekend for the past month. Ordering online would be even cheaper (sic)
    Jun 2001
    Boise, ID (USA)
    This is for my house
    I dont know, I guess I was just scared of the P4 because I had a bad experience once... Maybe I will just get a p4?
    As for the raid array, I was was going to use striping so it will be faster access...
    I guess I should just get a P4...
    I didnt get much sleep last night..
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    RAID0 is nice, but as im sure you know, one drive dies, you loose evertyhing, but really getting 512+ ram will be a better investment first if you're going to be doing intensive things. And why not get a p4 northwood and a rd/ddr setup (or an axp ).
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Sep 1999
    Yarmouth NS, Canada
    My vote goes towards the Athlon XP.. Cheaper and faster... Also, why are you using a regular SDRAM system? DDR is the way to go (if you decided to go with a P4 or an XP).
    MP3 Cavalier - http://www.mp3cavalier.com
    MP3 Grand Prix - http://www.mp3gp.com
    Jun 2001
    Boise, ID (USA)
    OK, You guys talked me into it.... I bought an Asus A7V333 motherboard with onboard Raid/USB2.0/Firewire, athalon XP1600+ processor, 512 K (megs, whoops) of PC2700 memory (333 MHz), and dual Western Digital 40 Gig 7200 rpm hard drives...
    I think this system should be pretty sweet.. Thanks for the opinions...
    Mike
    Jan 2002
    Chicagoland, IL
    Heh, 512K eh? And this is just friendly advice, but while the concept of onboard raid is nice, if you ever want to upgrade your motherboard/processor while still keeping the data on the raid array, i would suggest a pci raid adapter (moving motherboards using onboard raid would most likely require you to destroy and rebuild the array, causing you to loose the data).
    -Nick
    Jun 2001
    Boise, ID (USA)
    Great advise... Question, if you disconnect the hdd's, you will lose all raid info? or is it stored on the mobo?
    Jan 2002
    Chicagoland, IL
    you can disconnect the raid arrays, and depending on the controller, its stored either on the drives, on the bios of the raid controller, or a combination of the two.
    -Nick
    Jun 2001
    Boise, ID (USA)
    Ok, then what about getting this?
    http://64.4.8.250/cgi-bin/linkrd?_la...yaccount%2easp
