ummm, even if we told you how to do it, i'd still be worried you might break it +_+
1. the tools you need to get most covers off is generally some type of prying device for the little clips that hold it (my 240sx didnt need any prying, it just popped off, but obviously a mustang is a lot different) the only way to know how to take it off properly, is either for someone with a mustang to tell you how, or look at a manual, other than that, just be careful
2. to move the headunit, as long as there arent any cables, should be fairly simple, mind you it might not sit perfectly if the cdplayer and headunit arent the same size, so some fabrication of a mount might be necessary (they look fairly close though) to get most cd players out, you just need a philips (star) screwdriver, pull it out and disconnect the wires
3. to properly mount ur swivel thing, you would need a plate of some kind to mount the swivel to, so be it aluminum, steel, whatever, you would need to make one, just find the mounting holes for the cd player (as im assuming thats where the swivel would go), and make a little plate that securely fits into those mounting holes, then attach the swivel to the plate and there u go
cant really help you other than that, sry
LinkBack URL
About LinkBacks
