Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Front and Rear Volume Match - Possible?
  1. #11
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    actually hes trying to make his volum control front and rear channels. which it should. if hes going to be watching movies he might want front and rears. A Y splitter from the front would band-aid what he needs instead of fixing the software issue. like i said it would work but he would no longer have a rear channel, only right and left. if its acceptable to him so be it. I personally would figure out whats really wrong and fix it.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  2. #12
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    you need to get a sound card that has a rear output so you can control front and rear sound level. any surround card will do that
  3. #13
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    Thanks guys, but none of this works...
    My speakers are set up correctly in the advanced settings... Four Quadrophonic Speakers. I tried 5.1 setup, but it didnt sound right and it still didnt fix it. So that didnt work....
    And yes, a Y-Splitter is out of the question. I want to have four channels, and I cant believe that something so simple is so hard to do? I would think this would be a standard thing to do? Lower both sets of speakers at the same time? If I had a four speaker setup in my house on a desktop I would want the same thing.....
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
  4. #14
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by we87
    you never did tell us what soundcard you are using...
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  5. #15
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    keep in mind that the only advantage of 4 channels is for dvds, and if you ever play a dvd with passengers, they arent going to be happy with only hearing the rear output in the back
    carputer - done.
  6. #16
    Nov 2005
    Dallas, TX
    Quote Originally Posted by scott_fx
    Its the on-board sound for my Gigabyte mobo. I believe it uses the AC97 Realtek hardware.
    Quote Originally Posted by shrinkydinx
    That is a good point. But I personally think that it would be better to have 4 seperate channels for DVDs and such anyway.... Having Surround Sound in the car is just a very cool thing for me
    The best solution I've found is a program called "VolumeTracker". It does exactly what I want it to do, whenver the front speaker volume gets adjusted, it matches the rear speaker volume. However, whenever I reboot the program doesnt save the changes and the default is to match the Fronts to the Wave volume.... Not the Rear volume.... I emailed the guy who wrote the program and he said he's working on it but he is on vacation at the moment. So in the mean time, Im looking for another solution.
    Dont most of the people on here have 4 channel set ups?
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 05-24-2012, 11:59 PM
  2. Rear speaker volume...
    By zummi in forum Media Engine
    Last Post: 03-06-2006, 02:26 PM
  3. Can I redirect volume buttons?
    By IntegraKarim in forum FP FrodoComm
    Last Post: 03-03-2006, 01:21 AM
  4. Is it possible to map different sound sources to front & rear outputs?
    By Dominik in forum Software & Software Development
    Last Post: 09-27-2004, 11:20 AM
  5. Replies: 4
    Last Post: 04-16-2004, 02:02 PM
