Results 1 to 10 of 16
Thread: Front and Rear Volume Match - Possible?
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    OKay, I got my carputer set up and the two front speakers and two rear speakers are seperate on my amp, however, when I lower the volume on the computer it only lowers the front speakers, and doesnt lower the rear speakers...
    So my question is: Is there a way to link the front and rear speakers so they lower and raise volume at the same time?
    Thanks In Advance for any advice/help...
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    try lowering the master volume, not just the front channels. What software are you running, or are you just trying to do this in windows?
    have a look at this. XxAndyxX was working on this. You might be able to get it modified to suit your application.
    Nov 2005
    Dallas, TX
    Quote Originally Posted by meddler
    For some reason my main volume IS my front speakers... In NMC, the volume doesnt lower the rears, and in Windows (Winamp Stand-Alone and such) the rears dont budge.... This is un-acceptable.
    I saw that application by Andy but it doesnt have rear and front support. I guess I'll try PM'ing him and see if he could re-write it.
    Any other ideas for the time being though?
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    ok.. what the hell are we talking about. when you lowe the master volume it should lower all channels. What sound card are you using? I use an audigy and i can control right left frotn rear you name it. and master controls them all. need mroe info to help you.. how do you have this wired too?
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    Nov 2005
    Dallas, TX
    I'm using the onboard audio with my motherboard, a Gigabyte GA-7VAXP. And for some reason I dont have a "master" volume anymore. I have a "Front" volume and thats what Windows defaults to the master volume. I know this because whenever I lower the volume on my media keys on my keyboard, it lowers the front speakers. Also when I single-click the volume icon by the clock in the taskbar, it brings up the front speaker volume....
    So, I need to link them together.
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Apr 2006
    Chicago
    cntrol panel->Sounds and audio devices.
    Check your advanced settings on the volume tab. check your advaced and properties in there.
    under speaker settings. make sure the right speakers are selected. along with going into the speaker volume button and check.
    it really sounds like your speaker setup isnt correct. and its not outputting like its supposed to. id start there. you might not be able to contorl front or rear but you should be able to contorl the total volume regardless. also might want to look at your wiring to make sure everythings plugged in correctly acccording to what the manufacture states. worse comes to worse, you could wire it to have the front jack split to go rear and front so its all coming out of 1 channel. its kinda rigging it and not the correct way but it works as a last resort.
    1 last thing i just thoguht of. you can makesure that you have the latest software from the mobo manufacture to control the onboard sound.
    My Worklog
    Aug 2002
    let us know if you find a fix for this.
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    y-splitter?
    carputer - done.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by shrinkydinx
    y-splitter?
    thats just a "band-aid" not a fix
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    May 2005
    Quote Originally Posted by scott_fx
    uh, no...
    all hes trying to do is make the voltage coming out of the rear outputs match the voltage from the front outputs. which is exactly what a y splitter does.
    carputer - done.
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 12-16-2006, 12:21 PM
  2. Rear speaker volume...
    By zummi in forum Media Engine
    Last Post: 03-06-2006, 02:26 PM
  3. Can I redirect volume buttons?
    By IntegraKarim in forum FP FrodoComm
    Last Post: 03-03-2006, 01:21 AM
  4. Is it possible to map different sound sources to front & rear outputs?
    By Dominik in forum Software & Software Development
    Last Post: 09-27-2004, 11:20 AM
  5. Replies: 4
    Last Post: 04-16-2004, 02:02 PM
