Results 1 to 10 of 18
Thread: Heat Issues
    Apr 2005
    Queens, New York
    Heat Issues
    I dont know if this happens to any of you but its ben getting hot over here in NYC like 90+ for the past couple days soon to hit 100+ but i know that not near some of what you guys get. But my carpc seems to not boot up the first time i get into the car. If i let the car run for a couple seconds to cool down with the AC, then try and start the PC it will start. This doesnt happen on the cooler days....
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    intermittant connections somewhere?
    when it heats up, they expand and come apart?
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    I dont see how, but its possible its thermal protection somehow. but then again when a pc gets up to temp its probably 140 to 150 degrees. you melt the chip at about 170degrees. and your only talking starting it in 90 degree weather. your car sitting in the sun lets say its 120 in there. it should still be ok. if its a concern and giving it issues. dont start it until your cars cooled down. if your using a m1 or m2 power supply, dont use the auto power on function just wire your power switch directly.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    Apr 2005
    Queens, New York
    Quote Originally Posted by yrean
    OPUS 120W
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Apr 2006
    Chicago
    Quote Originally Posted by Cheekz185
    OPUS 120W
    check the connection from j9 to the mobo. or wire the power directly to the mobo instead of using the startup shutdown built into the opus. have you looked for any flashing lights on the opus? are there any when this happens?
    heres a link to the opus manual. http://www.mp3car.com/products/DCX3-...uick_Guide.pdf
    My Worklog
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    BIOS is probably failing to post due to the excessive heat in the chips and the hard drive.
    Mine does this, sometimes it will just bearly boot up, but then runs like a 80386 with about 4meg of RAM
    Last week my CPU hit 86 degrees C and the PC restarted, then said insert system disk... Got it in the house for some diagnostics and it had fried the harddrive contents to oblivion - Had to do yet another rebuild, but this time found a couple of hundred bad sectors on the drive And one of the VIA chips on the board has some faint brown staining on the top now, still seems to work ok though when its not getting silly hot
    If case temps go over 50deg C and CPU temps go over 70deg C then you will experience problems.
    And I was told that generally a CPU will meltdown if it exceeds 85deg C core temperature.
    Sounds like you need some big *** 120mm high CFM fans pointing at the board
    One 80mm (1500rpm) fan over my mobo drops the temps by nearly 20degrees
    You also need to make sure the case has adequate ventilation and fans.
    Maybe using a watercooling system is an option for you. Its not for me as I can't find a heatsink/radiator/heat exchanger which fits the SP13000 CPU.
    When winter comes round though you'll have the oposite problem, too cold and your HD will not spin up properly cause the cold makes the spindle grease go too thick and it stops it spinning up to speed, and you may be at risk of condensation on the circuit boards.
    HTH
    John
    Apr 2005
    Queens, New York
    I am sure this will prolly help figuring the problem but the opus beeps when the pc doesnt turn on. It goes BEEP---BEEP---BEEP ect. its not like BEEP BEEP----BEEP BEEP.....
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Apr 2006
    Chicago
    you sure thats the opus and not the motherboard. I had a mobo before that beeped like that when it hit the thermal protection.
    My Worklog
    Apr 2005
    Queens, New York
    Quote Originally Posted by ShawJohn
    HTH
    John
    WEll i have a total of 4 i think they are 80mm or 60mm fans in the case directly on the mobo and the case temp stays below 100 degrees F usually aroung 80-90 F
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    May 2006
    San Jose, CA
    hmm the beeps sound like the motherboard/BIOS beep codes. You should look up the beep codes for your mobo and start there. It is prolly a simple fix.
  1. Xenarc Heat issues.
    By IntellaWorks in forum LCD/Display
    Last Post: 07-21-2006, 07:17 PM
  2. Heat Issues?
    By Preston Masters in forum MacCar
    Last Post: 05-05-2006, 01:50 AM
  3. CD/DVD Slim Enclosure Heat issues?
    By jzgt in forum General Hardware Discussion
    Last Post: 07-11-2005, 11:14 AM
  4. opus heat issues
    By jjjewett in forum Power Supplies
    Last Post: 04-20-2005, 09:06 AM
  5. A few newbie questions ( heat issues etc.. )
    By Scorpnstail in forum Newbie
    Last Post: 03-05-2004, 05:27 PM
