Results 1 to 10 of 13
Thread: Which is a optimal place to put the pc?
    May 2005
    Since my laptop has stopped working my project was put on hold. Now im looking for a computer that either small enough to put under the passenger seat or in the trunk where my cd changer is. It a lexus sc300. Any thoughts? I dont want to go with the aopen or mac mini. Something relatively inexpensive. P3or4. I been searching on ebay and came across the old compaq ipaq or AMD's NEW " Mini portable computer"
    i considered this http://cgi.ebay.com/Gateway-eSeries-...QQcmdZViewItem
    Mar 2006
    Colorado, but Canadian!
    Well if you build it yourself than a Micro-ATX will fit under a seat comfortably. As well as a nano-itx, or Flex-ATX. If it is going in the trunk, than who cares about size?
    If you don't want to build it yourself, you can get the Ampie case fully built with M1-ATX, M10k, and RAM for real cheap from the store. Of course, if you do it yourself you'll save.
    Any reason you are looking at full systems and not just components?
    1.9in x 2.9in -- 47mm x 73mm
    May 2005
    Im looking at full systems because Ive never built a computer before. I know about them but I never messed around to build one. I only installed a tv tuner card and a cd writer. thats the most ive done.
    As far as the trunk, I want it to fit in where my cd changer is. I will junk the changer since it doent work.
    As for the itx systems are they fairly easy to build with the convential components found at pc stores?
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    optimal place to put a computer?
    how about IN the car
    jus kidding , anyway, u can put them anywhere that they'll fit, it doesnt matter really, people have them under seats, in the trunk, in the dash, doesnt matter
    itx arent really any different, just really small
    Mar 2006
    "itx" refers to the form factor or the size of the motherboard. Basically a nano-itx is about 6" by 6". Very small. A Micro-ATX is a maximum of 9.6" x 9.6".
    Basically when you put them together, all the parts are standard. Very easy to do. Get a Power Supply, like the Opus or M2. Get a standard desktop Hard drive. And get some RAM. BAM! You're done.
    If you want small go itx. If you want power, go atx.
    Or if you want itx and don't want to build it yourself, then the store has pre-built ones or even a kit avaialble so they send you the parts, and you put it together.
    And eventually, something will go wrong, and if you don't know what's in it or how to try to figure it out, you will be out a lot of money.
    May 2005
    hmmmmm juss put it all together? lol its that easy. I guess what im thinking about is the processor. Or do these cases come with them already.
    Mar 2006
    The via boards (nano-itx) come with the cpu soldered on. Basically, good to go! Really easy! That's why I suggest you build using a via board if it is your first build because it is sooooo easy. Less stuff to mess with. Also low power - low heat and low power consumption!
    Mar 2006
    Actually to correct myself, I do have a via c3 800Mhz Micro-ATX board lying around in my basement somewhere. So the via boards are not exclusivly nano.
    May 2005
    I checked the store.... i get it now. Get a ampie, ram, hd, VIA EPIA M10000 Mini-ITX Mainboard, windows xp. anything im missing?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Power supply, screen?
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  3. EWF in place of Deep Freeze for Home PC?
    By migel628 in forum WinNT Based
    Last Post: 02-22-2005, 12:53 AM
  4. Can I put Pc speakers on my computer car?
    By prado_sergio in forum General Hardware Discussion
    Last Post: 08-26-1999, 01:11 PM
