Results 1 to 7 of 7
Thread: Delco AUX Cable Pinout Fool question...Need Help...
    Aug 2006
    Mexico
    Hi...
    Probably the answer to my question have been already posted somewhere in the forum but I did try to find it without a good result.
    I have a Delco cassette head-unit on my 99 chevy-malibu with an Aux button model 16255311 posted in http://www.corvetteradios.com/UsedDe...tteRadios.html
    I want to adapt my Ipod to play it directly from the Aux Input of the HU, I know that there are a bunch of "After Market" cables for this purpose but they are somehow dificult to get here in Mexico.
    Can anybody post or send me a cable configuration for this purpose
    In advance thank you for your help
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by gbrocker View Post
    Hi...
    There should be nothing to it.
    Get some 1/8 stereo plugs, and some audio cable with 2 conductor and a shield.
    Then, the shield goes to the top most band of the stereo plug, then 1 conductor to the middle band, and the other conductor to the pin, OF BOTH CONNECTORS.
    Done, just plug it in.
    OR,
    get this, http://www.allelectronics.com/cgi-bin/item/CB-389/117/12"#39;CABLE,_3.5_MM_STEREO_PLUGS_BOTH_ENDS_.htm l
    Michael
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Without having a slave unit attached, you need to see if you can find yourself an AUX-GM9. That'll emulate something being attached to the unit and enable the aux, also giving you RCA inputs. I don't know of any other method than that offhand.
    Wiredwrx: You're going on the assumption that there's a 3.5" jack on that radio, which there isn't. The AUX button is for a slave unit, tape or CD.
    Aug 2006
    Mexico
    No Slave unit attached
    I dont have a slave unit attached to the head unit, and the head unit does not have a 3.5" jack input...
    Is there someway to fabricate or emulate AUX-GM9, or does it have somekind of complicated electronics..?
    I was thinking about a Cable with a connector to be attached to the head untit on one end and in the other end a 3.5" jack to connect to the ipod or any audio device...
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Tape adapter baby
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    May 2005
    Conyers, GA
    Unless you go with MatrixPC's suggestion, you'll either need the GM9 or an external tape deck for that unit. There are (so far as I understand) complex electronics at play that's more than tying a couple of wires together to get the headunit to recognize that something is plugged in.
    Aug 2006
    Mexico
    Thanks for your sugestions, I think I'll have to stick to the tape adapter....
    Regards
  1. Delco aux in......
    By BullyDog in forum General Hardware Discussion
    Last Post: 02-12-2006, 10:33 PM
  2. Cable Question for the LCD Guru's
    By xanimal in forum LCD/Display
    Last Post: 06-24-2002, 05:18 PM
  3. IDE Cable Length Question.
    By BeAR in forum General Hardware Discussion
    Last Post: 10-18-2001, 01:48 PM
  4. audio cable question
    By daver in forum General Hardware Discussion
    Last Post: 10-04-2001, 02:04 PM
  5. Alltech Elc.LCD cable question
    By subarump3 in forum General Hardware Discussion
    Last Post: 11-29-2000, 10:51 PM
