Results 1 to 10 of 13
Thread: Wire gauge Q
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    Wire gauge Q
    Ok, as far as I can tell, according to this site (http://www.powerstream.com/Wire_Size.htm) I can only run 2.3A on 18 AWG wire. If I use 2 18AWG wires does that mean I can draw a max of 4.6A or is there a more complicated way of adding 18 AWG and 18 AWG?
    Jul 2006
    Springfield, IL
    Why not just use a larger wire?
    "It's a blessing . . . and a curse."
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Siezmik View Post
    Probably because he has a bunch of 18 and he doesn't want to buy thicker wire, or it is cheaper to get 18 then whatever he really should be using.
    Technically, you could do that.
    Michael
    Feb 2005
    Barrie Ontario
    no, it's cause I wanna set up a wire harness for carpc using an ATX style connector, and it has 18AWG wire already connected to the pins. So i was wondering if it would work if i used 2 or 3 wires for power in the plug, the same for ground, and then I've got all sorts of other pins for other stuff, like my XM, monitor, USB hub, amp remote leads, etc. Basically I just wanna be able to unplug one big connector, plus the USB, VGA, 1/8" audio plugs and serial connectors to get carpc out instead of 10 little stupid crimp connectors and then all the rest of the ****.
    EDIT:
    Can someone recommend me a connector that will be more suitable for the above, something that might take a 10AWG that i can use for power and ground and then smaller wire for all the other stuff?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    look up anderson powerpole connectors. they come in various sizes and can be hooked together to form one connector block and you can do it so it can only every be connected one way.
    they are easy to assemble and use good contact area silver plated contacts.
    Mar 2004
    Bristol
    http://www.andersonpower.com/products/pp/sp.html
    also search for powerpole. i recommended them to people a while ago.
    Feb 2005
    Barrie Ontario
    Looks like a cool product, but their store is firggin confusing. I've got no idea what to buy LOL
    Mar 2004
    Bristol
    i think mouser and digikey do em.
    Mar 2004
    Bristol
    as i said...search:
    These are awesome connectors
    Feb 2005
    Barrie Ontario
    i found a store that sold them, but they wanted an extra $35 handling fee for orders under $200. I'll keep lookin tho THanks
  1. Pseudo-FAQ: What Do I Need For A Carputer?
    By Maheriano in forum General MP3Car Discussion
    Last Post: 07-03-2006, 02:04 PM
  2. finding connectors for 10 gauge + wire
    By VW_Carputer in forum Newbie
    Last Post: 05-31-2006, 12:10 PM
  3. what gauge wire to run from fuse block to trunk?
    By MP3GTP in forum General Hardware Discussion
    Last Post: 03-30-2005, 04:17 PM
  4. Replies: 11
    Last Post: 03-09-2004, 09:59 AM
  5. Routing power button to front of PC. Can wire be too thick of gauge?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 09-27-2003, 02:32 PM
