there's a difference between shock and vibration.
Shocks are more sudden, violent and last a short time. Vibration is constant, low intensity.
A laptop HD can withstand up to 200G operational SHOCK, and 800G non-operational... quite a bit. However vibration is more damaging, because it occurs all the time, every time. Just make sure u dont bolt the HD down to the case which is then bolted to the car chassis. Every bump and shake will move from the road directly to the HD spindle/arm. You MUST uses some rubber strips between the HD/case to absorb some of that vibration.
Dont mount it on an intricate rubber band arena or such... they dont help.. and all that bouncy bouncy might actually make things worse. Get a good quality IBM Laptop HD and it will last a long time.
You should also realise that there is a trick to HD mounting. The rule is... you should always FORMAT the HD in the exact spacial orientation you plan to use it. Say you want to use it sitting on its side... then format it that way when you start out!! Placing a HD in a position that it was not formatted in, will cause an increase in read error rates.
LinkBack URL
About LinkBacks
, Im installing the carputer in the dash, last time I had the hd mounted to the top of the case with a little cage I made, I need to know the best way to reduce shocks on it(some sort of padding maybe?).
) Im also making a case outta wood this time, as my brother is a carpenter(not from the group).
