Results 1 to 10 of 13
Thread: Aopen Mini Heatsink + Fan
    Jan 2006
    All, I just got my pc back from repair (wouldn't boot up)and I see they changed out the Heatsink and fan. They said they tested it out and had it running for 24 hrs straight but when I installed it and booted it up I found it would turn off after about 20 minutes. It doesn't appear the fan is turning on at all. They said I should send it back and it would take about another week or so. Any ideas? Should I send it back ?
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    There is not alot of info on this unit you are talking about. Is this the mini computer or the motherboard. Be more specific.
    Jan 2006
    Sorry, I don't know to much about computers. It's the Aopen Mini 915 with a pentium M processor. They pretty much replaced the motherboard and heatsink and now the fan won't come on and it's causing it to overheat
    Jun 2006
    Houston, TX
    Quote Originally Posted by hpric View Post
    try opening it up to see if the cable is loose. if its not send it back to them sucker. Make em pay for shipping since they sent it back to you mess up again.
    Jan 2006
    I checked the cable and it's fine. I also removed the heatsink and re-installed just in case but still nothing. What ****es me off is the downtime, I've already been without it for a month and I just got it back yesterday. Oh well, off it goes for repair....again.
    DIGItonium
    Guest
    After giving it some time to cool down, does the CPU fan spin again when you power up the system?
    Apparently the CPU fan smart fan controller is setup with a high turn on temperature threshold. You will need to access the BIOS to quickly change the threshold settings so the fan never turns off even at low temps.
    Jan 2006
    Negative, I think the fan does not come on at all. When I turn the pc on you can't here it spin at all
    DIGItonium
    Guest
    Do you have a cable that will allow you to connect the fan directly to the power supply to "force" it to spin up?
    Jun 2006
    Houston, TX
    He got a mess up comp. Return it to them suckers.
    Jan 2006
    Sent the system back again (3rd Time) they said the heatsink and fan were bad (why send it to me then?) Now I have to wait another 2-3 weeks.
    I'm thinkin of replacing this pc with something more "off the shelf" friendly
    Any ideas?
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Aopen Mini 915 **DEAD**
    By hpric in forum General MP3Car Discussion
    Last Post: 09-13-2006, 08:01 AM
  3. Pentium M CPU Heatsink or Fan?
    By DaveB in forum General Hardware Discussion
    Last Post: 02-26-2006, 02:58 PM
  4. Pc Mini
    By fungke in forum General Hardware Discussion
    Last Post: 06-02-2005, 04:43 PM
  5. Aopen mini ATX PSU !
    By Avner in forum Power Supplies
    Last Post: 03-04-2004, 10:53 PM
