Results 1 to 9 of 9
Thread: Pioneer stacker cable help needed
    Jan 2002
    Melbourne Australia
    Hey people I got a pioneer stacker cable ( i think its called a p bus cable also) a few months ago off spud 42 he is another aussie mp3 car member. Problem is soon i will be putting my pioneer deck into my car and i wanna know which wires on the cable i need to use to hook it up to 3.5 mm stereo plug on the back of my soundcard. One end of the cable has the plug on it and the other end has been chopped of. On the chopped end there are 9 wires which are the folowing colours ORANGE YELLOW BROWN WHITE RED BLUE BLACK and there are another 2 silver wires which have no insulation around them.
    I just wanted to know how can i hook this up to a 3.5 mm stereo plug and which wires are which took hook up to the 3.5mm stereo plug.
    Also are both end of the p bus cable the same.
    The only picture i have found on the net is this one below
    I think there was another one going around with the colours on it but someone told me that it was wrong and to ignore it.
    http://austmp3car.tk
    Jul 2000
    Ottawa, Canada
    I used the other diagram, but unfortuatly the colours of my wires didn't match it's and i had to trace the wires back to the plug end and connect them there.. I can post diagram with revised colours if you want.
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
    Jan 2002
    Melbourne Australia
    Yeah can u post it up for me man. That will be a lot of help. Thanks a lot. Will the wire colours be the same as mine
    Jul 2000
    Ottawa, Canada
    This is the diagram that i followed
    and this is the colour of the wires at the end of the connection.
    So brown and black are ground, blue goes to Left signal, and yellow is signal Right
    Im not sure if yours will match, but the first time i tryed and messed up all i got was a loud buzz. (ie nothing broke)
    Jan 2002
    Melbourne Australia
    No worries thanks for the pictures man. I understand the top one u posted with the 2 diagrams. In the next few days i will try and wire it up and see what happens hopefully nothing blows up lol.
    Does it matter if both left and right channels both have the same ground. I have been told that it is not good for the quality of the music.
    Oh yeah how come the diagram at the botom has pin 8 covered do i worry about that.
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    I just finished doing this today, i`ve been meaning to do it for ages since it sounded horrible the 1st time i tried it Anyway, it now sounds perfect (tested it with minidisc), and I have the grounds soldered together, since i'm using a 3.5mm jack on the end of my lead.
    -=TIP=-
    I never had a proper poineer plug like you, so i had to improvise: After loadza mucking around with jumpers, i eventually discovered that a cdrom audio plugholes perfectly lines to with the pins on the headunit. I used an angle grinder to make the plug thinner so it would fit, and this sorted out pins 11,10 and 9.
    For pin 7, i pulled out the metal part of the cdrom connector which would have gone to pin 8 on the headunit, wrapped it in electrical tape to prevent shorts (i done all of this after soldering, btw), and just put it on pin 7.
    I then tested it, no problems there, then i covered it in copious amounts of electrical tape to stop it from being pulled out the back of the head unit.
    -=WARNING=-
    Don`t put more than 1 volt of audio into your headunit, it could damage it (at least thats what pioneer says).
    Jan 2002
    Melbourne Australia
    Thanks for the info MikeHunt79. I have been busy at the moment so, it maybe a few days before i start making up the rest of my cable. So you just used a common ground which is the yellow wire (pin 11) and the blue.
    I have a old isa soundblaster 16 and i dont think it will put out more than 1 volt lol. What sound card are you using. Did you have to turn down the volume on your pc to like drop the line out voltage. (can this be done)
    Aug 2001
    Wow, 200th post... I spend way 2 much time on here... Anyway:
    Turning down the volume on the line out will reduce the output voltage. I used a multimeter to find the output of my soundcard.... I`m gonna use a SB Live, and the maximum output voltage is around 2v, so i`m gonna have the output volume at 50%. If the volume was set to high, you would hear it anyway, as it would sound distorted. Good luck.
    Jan 2002
    Melbourne Australia
    Thanks for all the info man. I will prob have a go at making the cable today or tomorow
