Results 1 to 4 of 4
Thread: G35 Housing + monitor - where is the real site???
    Nov 2006
    Hello Everyone,
    I am really interested in purchasing the 05-06 g35 housing + 700tsv, etc., but my only problem is the following. How do i install it? Is it auto or do you have to pull it out yourself? Is it easy to install yourself? Can any larger monitor fit? would you recommend the TS?
    Im sure i can get all my answers from Digitalwheelz.com, but unfortanately, they have been down for 5 days or more, so that is basically what is pending me from buying it.. thanks!
    Nov 2006
    I have the 05-06 with the 700tsv. You have to lower and raise it manually, they said their wasn't enough room for a motor. A bigger monitor won't fit. I haven't installed it yet, I was waiting for my Carnetics power supply to come in. Luckily it came in today, so I might put everything in this weekend.
    If you get the touch screen and it doesn't recognize your finger inputs, then open the case and check to make sure they connected all wires. I did allot of XP trouble shooting for it to end up being a hardware issue. GRRRR.
    Nov 2006
    I've up loaded the two word files that are from the site. Hope it helps.
    http://www.psedog.com/G35/G35ScreenH...stallGuide.doc
    and
    psedog.com/G35/G35ScreenHousing_InstallGuide.doc
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Let me know if you have any questions on my install. Also, check th elink in my .sig for my install thread. It might answer any questions, as well.
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  1. G35 Housing Only: Out of Stock
    By McFreak in forum General Hardware Discussion
    Last Post: 02-08-2006, 08:25 AM
  2. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 09:01 AM
  3. Replies: 19
    Last Post: 07-03-2004, 07:39 AM
  4. Lilliput installation in TM-701L housing extras
    By archimense in forum LCD/Display
    Last Post: 06-13-2004, 04:13 PM
  5. Writeup Lilliput installation in TM-701L housing
    By spyhunter in forum LCD/Display
    Last Post: 05-17-2004, 06:58 PM
