Results 1 to 10 of 14
Thread: Onstar alternative
    Newbie whteglve's Avatar
    May 2006
    Clemmons, NC
    Onstar alternative
    Do you folks know if there is an alternative to Onstar out there? Or is there a way to unlock my cars doors if I get locked out?
    Aug 2006
    Boise, Idaho
    No, but a hide-a-key works real well!
    May 2006
    Clemmons, NC
    I know, but that doesn't work if your handles are shaved. Plus I'm a little hesitant about leaving an extra fob or mounting an extra button somewhere on the car.
    Newbie Dingo509's Avatar
    Aug 2005
    Washington, USA
    what do you mean extra button? You have to have buttons for the electric latch as it is, otherwise you'll never get in. I have helped build alot of Street Rods and we shave the handles on almost all of them. Normally we have a small set of jumper terminals that you can hook a set of wires to that will pop the door if the battery is dead. these don't have to be mounted together, theoretically you could have the positive at one end of the car and the negative at the other. Or you could just ground to the frame and have only one terminal for positive. if you do it this way though make sure you have the wires hooked up so that it will UNlock the doors not Lock them.
    You can also mount a small air cylinder inline next to the door popper then run the airline to a schrader valve somewhere. if you pick the right cylinder you could use a small jumper hose and take the pressure from one of the tires. We did this on one car at the customers request, it seamed weird at the time but i think it's a better way to go personally as it negates the need for a set of jumper cables.
    Dingo
    Progress: Installed and working. Needs some cleanup and trim work done. now for complete integration.
    91 Jeep Cherokee 8" custom lift, 3/4 ton running gear 36" swampers, Snorkel, Onboard air, Onboard Shower. Now with in dash PC!
    May 2006
    Clemmons, NC
    I don't have ANY buttons on the outside of the car. I use a remote with the buttons on it. That would pointless the first time you had to use it. For anyone watching (maybe I'm paranoid), "Hey look here is my button to get into my car. You're welcome." Yes, I thought of the dead battery scenario, thus I mounted a pair of remote battery terminals. Thus if the battery dies I can use jumper cables and THEN use the remote. But what if I leave the keys and remote in the car. Oh well, the search continues.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Get another remote and keep it at home? Just don't lock the keys inside when you're out.
    Aug 2005
    Washington, USA
    Okay i see what your doing. So then in addition to running the jumper terminals to the battery, run smaller ones to the door solenoid itself. That's why i was saying run only one. just the stud for the POS. You can ground anywhere. all you need is a stainless bolt and some plastic washers to isolate it. Depending on how you do it, even if somebody knew the stud was there, they still couldn't get in. you could also run a door contact strip. like this:
    you could have only ONE going to the pos side of the solenoid us the frame for ground and set the rest to trigger the alarm. with 5 terminals that only gives the gy a 20% chance of getting it right. Plus if you go directly to the solenoid the dome light switch will still set off the alarm. don't mount this easy to get to or see. like inside the framerail or something (if you can get to it)
    Dingo
    Oct 2004
    NY
    I used to leave 2 screwheads exposed in a fenderwell that lined up with a 9v battery, even if the battery died it was as easy as finding the nearest place to buy a 9v.... a freash one actually poped the door..
    May 2006
    Clemmons, NC
    I like that idea, Dingo. Thanks
    Mar 2006
    Colorado, but Canadian!
    As an alternative sort of thing as a back up that will only work with the battery charged is the Auidovox CL-100. It is a satellite paging system. Lifetime Activation when purchased. Then you just call a 1-800 number, and enter a pin number. From there, you can unlock/lock doors, roll down windows, open your trunk, start your car, whatever is hooked up.
    Costs about $50-$100 on eBay and about $350 in a local retail audio shop.
    1.9in x 2.9in -- 47mm x 73mm
  1. OnStar review from a CarPC guy.
    By IntellaWorks in forum General MP3Car Discussion
    Last Post: 07-25-2011, 10:10 PM
  2. Replies: 26
    Last Post: 08-14-2008, 08:49 PM
  3. Anyone Tried Using the OnStar Mic for Voice Input?
    By bry21317 in forum Input Devices
    Last Post: 03-06-2008, 02:41 PM
  4. OnStar GPS Interface
    By Harry5150 in forum GPS
    Last Post: 08-10-2005, 10:07 AM
  5. Wi-Max : A viable alternative to Wi-Fi?
    By Maxis24 in forum Wireless Communications
    Last Post: 03-26-2004, 06:35 PM
