Results 1 to 7 of 7
Thread: Usb Hub Power
    Constant Bitrate Perrosky's Avatar
    Feb 2006
    NJ
    Arrow Usb Hub Power
    Hello, I'm about to install my first car pc next week and I was thinking if its a good Idea use te positive and negative from one of the molex of my opus 250w psu. or if it's necesary buy a point of load.
    THANKS. b
    One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
    Mar 2004
    If it's of the appropriate voltage, it'd work perfectly fine. That's what Ive been doing for the past few months with my hub
    Feb 2006
    NJ
    umm...?
    Quote Originally Posted by dyne View Post
    I will apreciate if you tell me how do I find out if the voltage if apropiate?
    thanks
    Elsewhere
    Quote Originally Posted by Perrosky View Post
    Look at the power supply for the hub. It will have a voltage rating somewhere on the power supply (probably 5v, as most USB hubs use 5v).
    If that's the case, you can pull 5v from your Opus PSU to power the hub.
    Tah-dah!
    How about the Wiki?
    Nov 2006
    On typical PC PSUs, yellow is 12v, both blacks are gnd and red is 5v. You should be able to use a red and black to power the USB hub - this is what I'm doing. You can multimeter it to be sure.
    Low Bitrate Gamer64's Avatar
    Feb 2006
    Holland
    I also need to power my USB hub when it comes in (D-Link DUB-H7/E). I need to power a DVDRW drive from the USB hub. It seems the pc hangs regularly when it`s connected during POST. that`s why i want to power it from a self powered hub. The HUB comes with a 220>5V/3A Power Supply. Personnally i think this can`t be a good idea to power this with a molex from my M2-ATX supply in my Car PC. Also the USB HUB needs to be at the front of my Car.
    Elsewhere
    Quote Originally Posted by Gamer64 View Post
    Then get a POL power supply that will supply 5v.
    How about the Wiki?
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. USB power question
    By maxxell in forum General Hardware Discussion
    Last Post: 04-13-2006, 04:06 PM
  3. Usb hub power source?
    By dmcdlrn in forum Power Supplies
    Last Post: 04-01-2006, 03:03 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  5. usb hub power problem
    By modUlarBeing in forum Power Supplies
    Last Post: 11-21-2004, 07:34 PM
