Results 1 to 3 of 3
Thread: psp to amp & RCA Y adapters
    Jul 2006
    hi guys,
    sorry if this is the wrong place
    sorry if this question have been asked already
    I did search, I did google
    so please no flames
    so I have two questions,
    here comes :
    I have a "conventional" car system and I want to feed MP3 into it
    I have a PSP and can't find a clever way to plug it in
    I'd like to rip the HU and use only the PSP
    it works ! but it's about 1/4 as loud as the HU
    I thought it would be easy to find some kind of preamp but NO !
    google floods me with stupid psp accessories
    or FM/tape adapters that I don't want
    car centers sale guys open wide eyes like "do WHAT ?"
    can't find the trick !
    also
    my door speakers are fed from the HU directly
    I plan to use a small amp to replace this (if/when I find a solution for the previous point) but this amp only have a RCA input, no output.
    for my two big amps, the one driving the woofer has input/output so it's fed by the RCA from the HU and it feeds the amp for the medium speakers
    I'd figure I could use some Y RCA adapters that I have but I'm not sure if this is correct...is it ?
    when I was doing studio, I know we used them but not sure it's the same stuff here (symetric/assymetric/whatever ?)
    TIA for your help.
    tchuss !
    Newbie 1bad2v's Avatar
    Sep 2006
    Hampton, VA
    Find a good quality Preamp/EQ. It will will take the signal from your PSP make is good for your amps. And then you can put as many amps as you want. You will get a few sets of RCA outputs from the preamp. And subwoofer control as well.
    http://www.pioneerelectronics.com/pn...tailsComponent
    It doens't really get rid of the whole "deck" but does add some great sound processing. Also you can wire 3 amps directy to it. with High-voltage outputs.
    Mar 2006
    Colorado, but Canadian!
    you don't need a PSP pre-amp. when you are searching, you are probably looking with "PSP" as a term. Dont. Just look for audio preamp that accepts 1/8 stereo and outputs whatever your amp will take (RCA's probably).
    No need for PSP stuff. If you can plug headphones in, you can plug a preamp in.
    1.9in x 2.9in -- 47mm x 73mm
  1. What Amp would do the trick?
    By LeythDC5 in forum Car Audio
    Last Post: 02-27-2006, 01:54 PM
  2. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
  3. What's up with my BRAND NEW speakers??
    By tbird2340 in forum Car Audio
    Last Post: 11-27-2004, 08:28 PM
  4. Sound not very loud have i bought the wrong amp
    By rickyaswell in forum Car Audio
    Last Post: 09-26-2004, 11:23 PM
