Results 1 to 5 of 5
Thread: Dynomat => Noise Proofing
    Dec 2000
    Iowa
    Post Dynomat => Noise Proofing
    Recently I've noticed alot of pinging and dinging on my S-10 mostly coming for the doors. Dynomat is the only way to fix this problem and I was wondering if anyone knows anything about doing it yourself or about how much it costs to get done. Also, are there any alternatives to sound proofing a vehicle. Anyways, please post what ya kno
    Thankx
    ------2000 S-10 Xtreme----------
    BookPC 433 5.6" LCD
    128mb ATI AIW
    18gb Laptop HD DVD
    GPS TV
    Wireless Internet
    Wireless LAN
    ***VIDEO SURVEILLANCE***
    AIM: Kinnish0 (Drop me a line)
    KinnishXtreme( IN CAR SN)
    Link To My XtremePC2001 Page
    Pic's of Install Here
    Jan 2000
    Alpharetta, GA
    Post
    Check out the forums a SoundDoman.com. Dynomat is a brand and therefore very pricey. It is basically justa rubberized product that is also used for protecting roofs on houses. It is referred to as Ice-Gaurd and you can get a lot cheaper than dynomat.
    JohnRam
    Feb 2000
    Rockford, IL (home), Southern IL (college)
    Post
    i put some in my car. Dynamat is expensive and i spent $40 to just do my 2 doors. Its cool stuff, but expensive. I also got some stuff off ebay that was cheaper and i used that on the rest of the car. In all, i do notice that there is not as much road noise and there isnt any nasty rattling from bass.
    2004 F-150
    Shuttle XPC, 80gig HD, Wireless Internet, DVD
    "How piMP3d is your ride??"
    Nov 2001
    Dublin, CA
    Post
    Rodkill is another asphault based sound damping material that works really well. Check out my sonoma: http://www.geocities.com/stevebang2000/Sonoma.html
    There is total of ten sheets in the vehicle, each sheet is 3X4 feet I believe.
    Here is the deal, this type of material lowers the resonance frequency of the material it is applied to by adding mass, it does not block noise. The lower frequency resonace requires more energy to make, plus your ear is less sensitive to these frequencies therfore lowering the overall noise.
    To block noise, you need to use something that traps air, like foam. Roadkill makes a very good closed cell foam that has a layer of asphault based material attached to it. This is excellent for blocking noise and reducing resonance frequencies. The only problem with this stuff is that it does not have an adhesive layer from the factory. You have to use a good contact cement to attach it. I added about 30 sq feet of this stuff after I found out about it, and it made a huge difference.
    In the end, the more you use the quieter your car is going to be. Believe it or not, I had a customer who brought two vehicle to me about a month ago. We put $5000.00 worth of these two types of Rodkill in both vehicles, well over 100 lbs in each.
    Car computer and console.
    Shuttle FV-24, 100gig, DVD, 10.4 VGA TFT, 866MHz, 128MB Ram, Keyspan remote, DC-DC
    Constant Bitrate monger's Avatar
    Nov 1999
    Good ole Maine. Gotta love trees and deer.
    Post
    Another alternative is a product called Grace Ice and Water sheild. Really cheap (30 dollars for a roll 5' X 40') and it is self adheasive. I would be somewhat warey about using a foam based material. Up here in Maine winter is not kind to vehicles at all, they get filled with snow and road salt. I would think that the foam material would have a tendiency to cause wicking; pulling the salt-water mixture to the metal body of the car and holding it there. If it were me I would rather go with the product that is MADE for waterproofing.
    Just a thought
    Monger
    ICQ-7207702
    UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
  1. Noise on audio from laptop
    By pip in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2006, 08:09 PM
  2. Replies: 86
    Last Post: 04-04-2005, 04:57 PM
  3. Damn Noise
    By Freeman in forum General Hardware Discussion
    Last Post: 03-20-2004, 01:37 AM
  4. Questiong about noise filter
    By helloman in forum General Hardware Discussion
    Last Post: 11-05-2001, 09:18 AM
  5. Power noise - the horror!!!
    By mtmsol in forum Power Supplies
    Last Post: 06-19-2001, 10:13 PM
