Results 1 to 10 of 13
Thread: Info on These Lilliput single din PC's
    Jul 2005
    gday been looking into getting a carputer again and came across this from liliput
    http://cgi.ebay.com.au/Lilliput-1-DI...QQcmdZViewItem
    Now.. i will be using my pc mostly for music playing and games.. using itunes... and maybe a few moto x games.. now if anyone has had any experiance with these single din PC's can u please give me some insite? or someone with the knowledge break down if this machine is capable of doing anything worth while..
    is it compareable to this unit
    http://cgi.ebay.com.au/VIA-C7-2-0GHz...QQcmdZViewItem
    thanks guys, ryann,
    Jul 2005
    bump.. anyone?
    Newbie tooby's Avatar
    Aug 2006
    St. Louis
    ok, well the first one, the 1 din indash one, it dosnt give you a screen of any time, and that is the ENTIRE point of having a carputer, being able to navigate around windows, not to just play discs, so unless you have a 2 din sized spot available and can stick a lilliput screen in the slot above this one, i'd skip it and go with a carputer under a seat or in the trunk and a 1 din flip out screen in its place in the dash
    for a mobo i went with the EN12000EG
    Aug 2006
    St. Louis
    thats my opinion anyhow
    VIA EPIA-EN12000EG - 512 MB DDR2 533 - M2-ATX - 60GB HD - VoomPC enclosure
    Jul 2005
    tahnks for the reply, more along the hardware side of things, how do u think it will run compared to a put together motherboard pc under a seat? either way ill be getting a touch screen to work along side it..
    Elsewhere
    The Lilliput in-dash PC is based on an EPIA M10000 motherboard. Its performance would be about the same if you built your own sstem based on the same motherboard.
    If you build a sstem based on other hardware, it will easily outpace the Lilliput system.
    How about the Wiki?
    Aug 2006
    St. Louis
    look at my sig, i'd honestly recommend the en12 or the en15, they are currently THE top of the line mini itx (what you would be using most likely) from VIA, and heat wont be an issue if you use those two
    Jul 2005
    i red a few reviews and i think this may be a good setup to start with.. what do u guys think.. i have no sort of judgement on mini pc's how would this be for playing some 3d games with? and playing music etc.? more then enough im sure?
    http://cgi.ebay.com.au/ws/eBayISAPI....ayphotohosting
    Elsewhere
    For playing music it's fine.
    It will suck balls for playing games.
    How about the Wiki?
    Jul 2005
    can you point me in a good direction for general usability? i generally wont use it for playing games. will be music.. videos and running my suspenion system..
    this seems more then fine? with 1gb of ram in it?
  1. Lilliput 7" Cable help needed. (Bad 9pin DIN)
    By FireAnt in forum LCD/Display
    Last Post: 01-07-2011, 12:50 PM
  2. Single DIN mount carputer?
    By Stacker in forum General Hardware Discussion
    Last Post: 08-25-2005, 03:58 PM
  3. FS: Single DIN case and slotload DVDROM for Via Epia MIIK
    By tf82 in forum Classified Archive
    Last Post: 06-10-2005, 02:16 AM
  4. Help!! 8" Lilliput din SAME COLOR WIRES!!!!!
    By Bizzar in forum LCD/Display
    Last Post: 03-31-2005, 09:12 AM
  5. Double Din to Single Din
    By loganm in forum General Hardware Discussion
    Last Post: 03-20-2005, 10:58 PM
