Hi Viren,
I tried both: first, connecting the PC to a 4-channel + 1-channel amps bypassing the factory head unit with a switch in the gloves compartment. I used a Soundblaster Live 24 with front/rear/c-sub outputs. I did that because the factory head unit only had stereo aux input.
The problem with this configuration was when the PC hung. You had to manually locate the switch and go back to the HU, or wait with no sound for the PC to restart. Not very convenient when in the middle of the traffic, but the advantage was the ability to pass the full signal (front/rear/c-sub) from the soundblaster to the amps.
The next step was to connect the on-board output of the PC to the aux input of the HU losing CMSS and other sound processing features in the soubndblaster. I found two advantages by using the last configuration: you can use the mute button of the HU, which is very useful when receiving a call, for instance. Also, it is possible to use the sound control features of the HU on top of the software in the PC (like the EQ or volume control.) Besides, if the PC hangs, you simply go back to normal HU operation by selecting another input in the HU while the PC restarts. However, the richness of the sound was better in the first configuration.
Finally I ended up keeping the second configuration and replacing the factory HU by an aftermarket with advanced sound processing features, which in combination with the amps and the on-board sound card provides an oustanding sound.
By the way, your technician is right: the relay is required due to the power levels involved, and the number of pins to move from one side to another when switching the amp inputs from the PC to the HU. The alternative is to use an array of switches...
LinkBack URL
About LinkBacks
