Increased resistance would make the resisters heat up, not the wire. When you replaced the resistor pack with the relays, did you match the resistance values of those resistors? As well as the current requirements? It sounds like something in those relays is causing an open circuit, which is letting too MUCH current flow, thus melting the wires.
LinkBack URL
About LinkBacks
