Results 1 to 10 of 14
Thread: mother board problem
    Dec 2006
    ok new to this forum and donno if this is right place to leave this post but anyway.........
    building car pc with
    Jetway J7F4K 1.5GHz C7 Mainboard
    12v car powersupply
    2.5inch 40GB drive
    i have this all in a homemade case and it works sometimes, turn it on and it beeps and boots up as normal but other times turn it on and it does not even beep, the fans turn on and the hard drive spins up but it does not even seem to reach bios? the monitor remains blank??????
    anyone got any ideas? may it be a faulty mother board?
    its standard and have "loaded optimised bios settings" and not been clocked or anything :s
    cheers
    Ralph
    Elsewhere
    Is it on your desk or in teh car?
    If it's in the car, how are you powering it? Inverter? DC-DC PSU? regulator/PicoPSU?
    Your statement of "it doesn't work" lacks the details needed to even begin to help you troubleshoot. It's like calling your doctor and telling him that your neck hurts. There's not a lot to go on for making a diagnosis.
    Although, the initial symptoms point to a power problem.
    How about the Wiki?
    Dec 2006
    its on the floor in my bed room but running from a car battery.
    its a 12v dc-dc car power supply.
    sometimes it boots/starts up as normal. but other times i turn it on and the fans spin/hard drive spin up and it just stays there, the monitor does not come up showing anything and it does not beep.
    so its failing even to reach bios???
    sorry if didnt give enough detail in first post
    Ralph
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    which power supply?
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    _
    Mar 2004
    Little Elm, Texas
    have you checked the voltage of the battery?
    if you're not running a charger on that battery you could be running into low voltage problems.
    Jan Bennett
    Dec 2006
    the voltage is fine and yea have a charger on it, also the power supply will run on voltages as low as 6v, how ever shuts the pc down if its runs lower than 11.2 for few mins.
    and its a ....
    M2-ATX - 160W Intelligent Car PSU
    https://linitx.com/product_info.php?products_id=917
    its really got me this one, want to update bios but cant as it does not have a floppy drive and i dotn have a bootable CD :s
    Ralph
    Dec 2006
    thought i just replyed but it seemed to disapear....
    i have a charger and anyway the poer supply should work on as low as 6v anyway so no problems there, its a
    really not sure what to do as its intermitant and i dont know how to update my bios as have no floppy drive and i do not have a bootCD.
    :s
    Ralph
    Elsewhere
    It's not you. It's an anti=-spam measure. Your posts were moderated, needing approval.
    Please don't take it personally.
    have you powered up the system using a regular ATX power supply to make certain all the components are functional?
    And are you certain the car battery has a full charge?
    How about the Wiki?
    Dec 2006
    no i havent, maybe that should be my next thing to cheak, might pop in PCworld today an get one, test it an then take it back lol.
    had another problem last night "c:\windows\system32\config\system" file went invalid so re installing windows now!!
    thing is i got the PSU/MB/HDD/RAM all froms ame shop so should have been compatable!
    and yes understand bout the anti spam thing!
    Ralph
    Jan 2005
    Scotland
    M2 is known to have some issues with some Jetway board producing the same symptoms as you have. Have a search and you will find a good few posts on it see if any are the same as yours.
  1. EPIA 5000 boot problem
    By linden_arden in forum General Hardware Discussion
    Last Post: 08-08-2008, 06:57 PM
  2. connecting a PSU to a board which doesn't a have 20 pin connector
    By al_kaholik in forum General Hardware Discussion
    Last Post: 12-02-2006, 03:21 PM
  3. WTB: lvds mother board
    By 0-0-7 in forum Classified Archive
    Last Post: 04-18-2006, 03:40 PM
  4. Case Ideas and Mother board choice question
    By girbot in forum General Hardware Discussion
    Last Post: 04-03-2006, 03:24 PM
  5. FV24 wasted space on video out problem
    By Mikesz in forum General Hardware Discussion
    Last Post: 02-22-2002, 08:20 PM
