Page 8 of 8 FirstFirst 12345678
Results 71 to 77 of 77
Thread: How to power a USB hub
  1. #71
    Oct 2007
    Westminster, CA
    Thanks to the info in this thread I powered my hub via splicing the AC adaptor and soldering the barrell to a molex connector. Anyways it works fine if I plug in the hub after powering up my board but it wont power up if I have it plugged in before.
    I'm guessing the PSU doesn't have enough amps to power everything at start up. Will this fix my problem?
    http://store.mp3car.com/ProductDetai...Code=PWR%2D022
    Thanks in advance.
  2. #72
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    No, its not the PSU, but the motherboard....... I had the same issue.... the board will turn on then immediately turn off..... I have this issue when I try to power the hub that is plugged into the onboard USB. When I use the power plugs on the hubs that are connected to the PCI USB card, i do not have the shut off issue......
  3. #73
    Oct 2007
    Westminster, CA
    Quote Originally Posted by HiJackZX1 View Post
    Hmmm... I'm powering my hub via 5V molex. I actually tried a PCI USB card and my board wouldn't turn on with it installed. So you think the problem is caused by the hub drawing too much power from the onboard USB port?
  4. #74
    Jul 2007
    Miami
    It could be a feature built into the PCI card, just like my motherboard has the feature, but the pci card does not..... there must be an option to turn it off.... You could also be right, maybe the start up voltage isnt enough? I know on my Opus i can set up the volts it uses to turn on and off.
  5. #75
    Oct 2007
    Westminster, CA
    You think I should change that little red switch on the PSU to a higher voltage? I never messed with that thing I hope it doesn't mess something up.
  6. #76
    Jan 2008
    If I were to purchase a USB hud that had an AC->5vDC brick could I just cut the brick off as stated before. Connect the positive wire coming from the HUD to the 5v rail on my Opus 320 and simply ground the other wire?
  7. #77
    Low Bitrate Belo's Avatar
    Jan 2010
    Buffalo, NY
    Quote Originally Posted by TJ31324 View Post
    i'm curious about this as well, but instead of going to the psu, i'd go to my cigarette lighter that turns off with the car.
    I was looking at this:
    http://www.newegg.com/Product/Produc...82E16817182057
    09 Pontiac G8GT [decently modded]
    former carputer owner, given up for iphone
  1. Power USB Hub with M2?
    By Arty13 in forum Power Supplies
    Last Post: 01-04-2007, 08:16 PM
  2. USB power question
    By maxxell in forum General Hardware Discussion
    Last Post: 04-13-2006, 03:06 PM
  3. Usb hub power source?
    By dmcdlrn in forum Power Supplies
    Last Post: 04-01-2006, 02:03 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  5. usb hub power problem
    By modUlarBeing in forum Power Supplies
    Last Post: 11-21-2004, 06:34 PM
