Results 1 to 10 of 15
Thread: Controlling Airbag system through PC..
    Jul 2005
    Ok, i got this idea from seeing the dakota digital systems (basically an overpriced setup used to raise and lower an airbag suspension car through a small, lcd and 3 buttons) and there price tag.. now basically i have a toyota hilux which suspension is setup on airbags and is controlled thru 8 12v Solenoids..
    now.. each wheel has an airbag and the air to that bag is controlled by a rocker switch in the cab, up operates one valve to to one airbag and inflates it. and the down will operate one valve which deflates the bag.. which in turn raises and lowers my truck.. so all up 2 valves per bag.. so 8
    now ive been wanting to do this for sometime and feel its finally within grasp after reading that topic about controlling LEDs..
    (Controlling LEDs through Car PC??)
    basicly all my switchbox does is zap each valve with 12v line and it opens the selected valve.. which lets the air thru..
    Sooooo in the end i want to create a flash program that looks cool and by touching each corner bag on the screen can raise and lower my truck.. even so a vbscript program or something to get me started... to be able to click a button on my touch screen which will send a current outside my pc to some sort of relay.like to a circit board on the pc to run to a relay to open my valve... i kno this is all confusing but i hope you guys understand.. how could i go about doing it? those kits from jaycar seem like they can do the trick.. but i just would like some more info..
    Ultimately i want to have 4 air pressure senders one on each airbag that sends the pressure just as a integer to a circuit which i can read in a program... as soon as i can do that... i can have preset buttons inside a program which on click will open the correct valves and using an IF statement relate back to the pressure coming from the senders and stp once reaching a number from the sender and set the truck up to a certain height.. and ill be able to do it all from a damn cool screen and wow alot of people who are buying these **** box systems with really lame basic lcd screens,... and this hopefully will cost me half the price. at least..
    Anyways... ANY help would reatly b appreciated..
    Ryann,
    Elsewhere
    Search the forums.
    It's been discusses many times.
    How about the Wiki?
    Jul 2005
    ok thanks for the reply. ive been searching and come across ALOT of info.. can u give me your thoughts on this and also some guidance into a decent realy board i could run with this..
    i think im going to go with this phidget board
    usb interface into my system..
    from there i also want to try and run 5 pressure senders to run into my phidget board.. such as these
    From there i can read all the info i need in a fancy flash program and shoot back out my phidget board onto a relay board and from there my solienoids.. im more fussed on getting that side of things done first rather then the pressure senders.. but id like to get a way to do that also.. that way i can have preset heights in my program..
    any thoughts or help from you guys? on a relay board and info on pressure readings.. thanks.. Ryann,
    EDIT: how would i go about implementing such a sender like this..
    http://www.swissarmyvehicles.com/sho...rtno=VDO360025
    May 2006
    Calgary, Alberta
    I have an air ride setup with the touchscreen control. It doesn't run through my carputer though. Yet.....
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jul 2005
    Quote Originally Posted by Maheriano View Post
    well from what i can gather it is really a fairly simple setup and in the end with a flash frontend for the system i should be able to make it look quite the professional system with animation of my actual truck in vector should be very nice..
    anyone with comments or ideas please post
    Jul 2005
    From what ive found i would be able to run this as my relay board?
    DC Opto-Isolated Output Board
    DC Opto-Isolated 4 Channel Output Board, suitable for DC motors and servos. Effectively control DC motors with this easy to control DC output board. Each channel is controlled by a TTL control signal, which can be connected directly to a microcontroller or control system. Board requires a 12V power supply.
    Features
    • Connects Directly to all Futurlec Training Boards
    • Opto-Isolated for Effective Isolation between Input and Output Circuits
    • LED Status Indication
    • PCB Terminals with Screw Fixing for Secure Connection
    • Fast Switching Outputs suitable for up to 3A @ 12Vdc
    • Dimensions: Length - 127mm, Width - 56mm
    This will output a 12v DC for use on my car, to zap my solenoids correct?
    Jul 2005
    bump?
    Nov 2006
    Adelaide
    That board only controls 4 DC outputs, i think you need to control 8?
    One up and one down valve for each wheel.
    Jaycar - so you are from Australia too?!
    Jul 2005
    Hey thanks for the reply..
    Yea id need 2 of those boards.. but they control the DC at what amps?
    NSW Australia here man
    Nov 2006
    Adelaide
    It says 3A 12V, that would be for each output you can control.
    Your valves wont need much power to activate, i think you should be fine with it.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. Controlling LEDs through Car PC??
    By ModRT04 in forum General MP3Car Discussion
    Last Post: 02-06-2007, 10:57 AM
  3. soun system in home ipod is louder then pc
    By ricecrispy210 in forum Off Topic
    Last Post: 08-13-2006, 04:21 PM
  4. remote controlling PC over Bluetooth?
    By whoracle in forum Wireless Communications
    Last Post: 12-30-2004, 08:02 PM
  5. Controlling Lights with the PC
    By Cryogen-x in forum Input Devices
    Last Post: 03-01-2004, 06:45 AM
