If you're knowledgable on electronics and don't mind taking that inverter apart, you can try using a circuit like this:to convert the switched 12v in your car to a 'momentary' press. That 'momentary' time can be extended by trying different resistor / capacitor combinations.
( From here: http://www.the12volt.com/relays/page5.asp )
In that diagram you would connect one side of the internal switch to pin 87 (shown as fused 12v) and the other to pin 30 (shown as momentary 12v). I have this setup with my monitor and it works great.
LinkBack URL
About LinkBacks
