Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 12V USB Hub, Help!
    Oct 2006
    12V USB Hub, Help!
    I've been looking, but I'm having a hell of a time finding a USB hub that accepts 12V DC input.
    I'm more than willing to chop off the end of an AC adapter, but so far all that i'm seeing are hubs with an AC adapter that changes the current to 5V DC.
    Much love to anybody who can find me a USB Hub that takes 12V DC input, regardless of whether or not I have to modify an AC adapter.
    I have everything finally done I just need more USB ports but I don't want to run a 5V line from the PSU all the way to the front of the car when I have an easily accessible 12v source already available.
    Or...
    Is there some kind of really easy way to step down 12v to 5v?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    There are many options, search the forum.
    Michael
    Oct 2006
    I already know there are many options for powering a hub, however the only available option I have is a 12V line, hence why I am simply looking for a hub that accepts 12V input.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by spoonraker View Post
    It is NOT your only option, it is just the option you prefer.
    Now, there probably are not any 12v hubs, since USB standard dictates 5 volts. No point in converting 110 to 12 and then doing it again inside the hub. Manufacturers use the cheapest method, and since they need to include a wall wart to power the hub, they include a 5 volt wall wart, to avoid needing additional regulation inside the hub.
    Your second question was how to convert 12 volts to 5 volts. THAT HAS BEEN COVERED, search for the answer. THERE ARE SEVERAL PRODUCTS THAT CAN DO THIS.
    Michael
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Agreed. You are very unlikely to find a 12v USB hub. As said there are other alternative methods.
    Oct 2006
    ok...I just figured that there would be some since 12v is like everything computer and car related...guess I have some searching to do
    May 2005
    Conyers, GA
    Not really. Most logic circuits in computers run at 5v. Everything USB is 5v. Just because a car runs on 12v doesn't mean there'd be something readily available as far as USB hubs go, for cars.
    Variable Bitrate Tissy's Avatar
    Sep 2005
    Essex, United Kingdom
    12v hubs are available, but they are not cheap.
    I have a 12v 4 port hub and they are excellent (different manufacturer though).
    Here is an example
    http://www.ms-visucom.de/cgi-bin/r30...14_select||21|
    Hope it helps,
    Steve
    System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Wow for 120 euro for a 12VDC 4 ports hub?
    I would buy a 5VDC hub for about 10-15 bucks and go t wally world and get an auto adapter that can do 1-2 AMP for another 25 bucks or one of the 5V POL in the store.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2004
    Sweden
    Or a 5 volt 2 amp voltage regulator (7805) for one dollar My external USB DVD drive needs 7.5 volts and I use a simple $1 regulator (7808) on a small heatsink to produce 8V (close enough). Worked great for 2 years now.
  1. USB hub does not always initialize on boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-29-2006, 03:41 AM
  2. Replies: 2
    Last Post: 09-26-2005, 09:59 AM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  4. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 12:07 PM
  5. usb hub with 12v psu
    By etrik in forum General Hardware Discussion
    Last Post: 06-30-2001, 01:06 AM
