Results 1 to 9 of 9
Thread: mini-itx to micro-atx case???
    Nov 2005
    Laguna, Philippines
    Can i use a micro-atx case for my mini-itx board?
    Would there be any problem on the mounting holes?
    Are they compatible? thanks!
    Elsewhere
    I don't think that the mounting holes will line up.
    How about the Wiki?
    Mar 2006
    Colorado, but Canadian!
    The hole sizes are somewhat correct. But it wont work. The micro-atx case has 6 screw holes 2 columns and 3 rows with 1 of the holes offset a bit. The itx has 4 (2x2) and the one that is offset is on a different side than the micro. So it will screw into a micro case, but the back panel will either face upor down instead of out the back.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2006
    Las Vegas
    but its not to hard of a task to remove the back of the case, drill (3) new holes is in the mobo mounting sheet and put some standoffs in it. You're not hurting the case any, if tou want to put a uATX back on it, the new holes are covered (use screw-in standoffs so that they can be easily removed prior).
    It's been a while...
    DIGItonium
    Guest
    Yes, it will work. You only need to use 4 instead of 6 screws to hold the mini-itx board down. I know it because I transitioned from a uATX to a mini-ITX platform for my project.
    NO MODS are necessary. The I/O plate will align itself fine.
    Mar 2006
    Quote Originally Posted by h3rk View Post
    but if the case has those bubbles instead of holes for standoffs you're screwed! (pun intended)
    Quote Originally Posted by DIGItonium View Post
    I went from my itx M10k to a uatx via 800Mhz C3 just for testing and it definately was rotated 90 degrees. Considering it is supposed to be a standard, this is weird. I switched back to my M10k though one reason being not to designanother case.
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    where did u find a micro ATX case... can't find any in europe
    Nov 2005
    Laguna, Philippines
    thanks alot guys. i'll but a uatx case later and do what suggested.
    I hope i can allign the i/o plate and pci slot as i'm planning to use
    pci wifi card.
    i'm from philippines and you can find any platform of case but not
    mini-itx.
    DIGItonium
    Guest
    Quote Originally Posted by 2k1Toaster View Post
    Yea, that's definitely weird. I switched from the MSI Speedster uATX to the Albatron mini-ITX. The board takes up the back corner at the I/O panel... no shifting. So I'm quite puzzled by the VIA layout.
  1. New OPUS MINI ITX Case
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 07-14-2006, 12:45 AM
  2. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 07:48 AM
  3. found a car adapter for mini itx case!
    By e36mp3 in forum General Hardware Discussion
    Last Post: 08-04-2002, 05:06 PM
  4. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 07:04 PM
  5. micro / mini atx system w/ LCD and all the goodies
    By gizmomkr in forum Classified Archive
    Last Post: 05-09-2001, 04:08 PM
