Results 1 to 10 of 14
Thread: why is my computer soo slooww?
    Nov 2006
    Thornhill eh?
    i have via epia m10000 and the boot is realatively quick (i think) hjowever it will not play the video bit of videos at anything watchable. I have yet to put it in my new car so i just use it inside for music. It plays the music without any stuttering, however if i start browsing around windows its slow at loading things as well videos play at less than 5 fps, although the audio is fine.
    i have run disk defrag and it does not really help.
    I have 1 gb of kingston ram, the frame buffer size set to 64Mb and the (graphics memory?) set to 256mb, i have an 80GB toshiba laptop drive.
    pic: could the fan be making it to cold? it keeps the Cpu at prolly a bit below room temp.
    Elsewhere
    The electronics of the computer will actually like the cold, although the mechanicals (HDD, opptical drive, fans) will not.
    1) Did you load the Via 4-in-1 drivers immediately after you installed Windoze?
    2) Did you load latest versions of all the drivers, or just the ones that came on the supplied CD?
    3) You don't need 256MB for graphics memory, but with 1GB of RAM that should be OK.
    4) Disable any/all unused devices in the BIOS.
    5) Disable any unnecessary/unneeded services in the Computer Management Console
    Don't expect miracles. It's only a 1ghz CPU.
    How about the Wiki?
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    are the vids encoded? is the cpu maxing out? i could be that you have a bad / cpu intensive codec.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by brendan View Post
    ipic: could the fan be making it to cold? it keeps the Cpu at prolly a bit below room temp.
    What kind of magic fan do you have that can cool below ambient temperature?
    Nov 2006
    Thornhill eh?
    the only vids i have tried so far are Divx files, I do believe i installed everything off the Via disk imediately, although i have not gone looking for updated drivers.
    Mar 2006
    Colorado, but Canadian!
    Believe me the video works fine once you get the drivers installed. The video drivers that windows installs as default, are crap. They work with showing the screen but not efficiently meaning no video playback.
    Even though you see a picture, make sure you go to the via site and download the S3 Unichrome Blah Blah Blah drivers for your board. YOU MUST DO THIS. Not optional. They come on the disk that came with the computer too, but you must install these. Preferrably just after the installation of windows.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2006
    Thornhill eh?
    i have become completely befudled after reaching this page : http://www.viaarena.com/default.aspx...D=1&CatID=1160
    i don't know which one to pick, im using an epia M10000
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Cool
    Quote Originally Posted by Rob Withey View Post
    Actually, with enough airflow and properly directed you can get below ambient. But I'm more familar with it in turbine engine theory (axial flow compressors mostly). You can have up to a 5 degree temp drop. same theory applies to carburetor icing. has to due with the pressure drop, it's called adiabatic cooling.
    I doubt that a little fan on a computer would be capable of such airflow, but I could be wrong.
    just throwing the info around.
    Cheers
    BJ
    Mar 2006
    Quote Originally Posted by vfinterceptor View Post
    Cheers
    BJ
    I don't know too much about adiabatic cooling, but I know that a little 80mm computer fan cannot do that! We're talking about changing the pressure inside the case!
    Oct 2006
    I think you're looking in the wrong places for your answer. I have an M1000 that functions perfectly, I didn't download any drivers for the video card, just the ones loaded off the CD it came with.
    I did, however, have the exact same problem as you. For me it had something to do with the settings of my frontend. I think the problem was with winamp running visualizations or something...basically it was a software problem and with a few configuration tweaks to my frontend it worked perfectly. I'll see if I can dig up the thread that helped me...
  1. Replies: 15
    Last Post: 10-08-2009, 11:02 PM
  2. The legalities of wardriving.
    By PURDooM in forum Wireless Communications
    Last Post: 01-29-2008, 06:26 PM
  3. Remotely turn on computer (not necessarily car)
    By Triggerhappy in forum Power Supplies
    Last Post: 06-22-2006, 01:23 PM
  4. What kind of computer to pick
    By pulz in forum Newbie
    Last Post: 02-02-2006, 05:08 PM
  5. Computer becomes unresponsive, inverter problem?
    By tsb4k in forum Power Supplies
    Last Post: 10-23-2005, 03:22 PM
