Results 1 to 4 of 4
Thread: ITX board and CPU that will run Vista
    Feb 2007
    so I just discovered the whole world of computers in cars and instantly decided I needed a media center in my car. I didn't even know about ITX form factor. It's been a dream of mine for years but I had no idea people were already doing it.
    anyway - i'm a huge media center fan. I have several at home and at work (work for MS) and I want to run Vista in my car.
    Has anyone tried running Vista on one of these ITX boards? Is it possible to use Micro-ATX in a car with the DC-DC power supplies? It seems like it would be easier to build a beefier box with micro-ATX especially since Vista needs a pretty beefy video card for all the media center 3D menu animations.
    open to any suggestions or advice.
    thanks,
    dan
    Oct 2003
    Copenhagen, Denmark
    I should think that a mini-itx board based on i945 chipset and a Core 2 Duo mobile 2 ghzish with 1-2 gig dual channel ddr2 should be fine for Vista. There is a thread about mini-itx core duo boards in the general hardware forum
    Not doing carpc anymore
    Low Bitrate justin146's Avatar
    Feb 2001
    Oxford, MS
    Quote Originally Posted by danwheeler View Post
    thanks,
    dan
    I run a micro ATX with a 200watt dc/dc PS. This is with a 72 watt AMD processor, 256mg Nvidia 6200, and two stick of DDR. I am probably right at the limit of the 200watts though. I will soon be replacing this with a spare 939 board and AMD 64 3200, because this processor uses less power.
    Turbocharged 2000 Explorer 5.0 AWD, SCT tuning software, Carputer w/ Athlon XP2600 and 8" Lilliput custom molded into dash, Terk Commander XM, Rand McNally and MapPoint, bluetooth, and 802.11x
    Feb 2007
    Quote Originally Posted by justin146 View Post
    thanks, i see your spec there in your sig. I'm not too concerned about size - i'd rather run cheaper, more common components like micro ATX and spend a little more on a good power supply.
  1. would a 500mhz cpu board work?
    By VW_Carputer in forum Newbie
    Last Post: 06-01-2006, 01:12 PM
  2. max cpu temps on a via epia board
    By megagoo in forum General Hardware Discussion
    Last Post: 05-21-2006, 02:33 AM
  3. *WTB* Mini ITX board with case and CPU
    By Kevin22 in forum Classified Archive
    Last Post: 02-18-2006, 09:32 PM
  4. Celeron mobile cpu on a standard s478 board
    By GuiltyLionel in forum General Hardware Discussion
    Last Post: 09-27-2005, 03:05 PM
  5. Dual CPU mini-itx board...
    By m3rdpwr in forum General Hardware Discussion
    Last Post: 10-07-2004, 06:08 PM
