Results 1 to 10 of 12
Thread: Puculiar Issue - Keyfob only works sometimes
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    Peculiar Issue - Keyfob only works sometimes
    My computer works nearly perfectly (with one software issue I have not figured out yet) but I have this one pesky problem. SOMETIMES, I can not lock my car with the keyfob until the pc completely hibernates. Once it hibernates, all keyfob functions work; trunk, lock, unlock, panic. Sometimes while going into hibernate all functions work as well. Then about 30% of the time, the buttons just don't work. Any ideas?
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Could be one of two things:
    Interference -- shield your CarPC better and look for loose connections and looped wires. Test this by using the keyfob at various distances from the car. Also, it would be nice to know where the receiver is, so you could aim towards it and see if it helps.
    Smart Car -- your car detects a load on the electrical system and it won't let you lock it up, forcing you to ensure you haven't left the headlights on.
    Oh yeah, check the batteries on the keyfob as well...
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Sep 2006
    Thanks for the quick reply. I do not know where the receiver is but I can operate the fob at various distances when pc is off from very close to very far.
    I think the second option is what it is but I was not sure. The thing I don't get is why does it work sometimes?
    Batteries are good and other keyfob has similar results.
    Lastly, it might be the receiver but I like option 2. So do I live with it or can I do something about it?
    Apr 2005
    Quote Originally Posted by jeffreyd_tx View Post
    Research if it's option #2 indeed.
    Check with knowledgeable members on Altima forums...
    Oh yeah, and read the car manual, especially see if it talks about forgetting to turn off you headlights.
    Sep 2006
    Cool. I will. I'll report back if I find anything. Thx!
    Feb 2006
    Remote
    Same problem with my 2006 Cadillac SRX, have to lock the doors with the button on the door if the computer is left on.
    Oct 2004
    NY
    put a diode on the ign feed line to the pc.... it may be backfeeding & the car still thinks the ign is on.... theres a good chance this is your issue...
    Feb 2006
    Thanks Turbo, I will try that and post results.
    Jan 2006
    Hey ducky55, did you manage to fix this problem? If so, how?
    May 2006
    Calgary, Alberta
    I'm pretty sure he fixed it about 2.5 years ago.
    But for anyone having the same problem, there could be a number of issues:
    - Car thinks you left the headlights on because there's a load on the electrical. To check this, try using your keyfob with the computer off and the lights on. If it still doesn't work, this is the case.
    - Batteries in the keyfob are dying, had this happen to me before. Or the fob itself is dead.
    - If you're running a wireless card in your PC, then it could be working on the same frequency as the keyfob signal and interfering with it. So once your computer hibernates and shuts off the wireless card, your keyfob works.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  1. Boot issue
    By Slippin3 in forum Power Supplies
    Last Post: 02-07-2006, 01:19 PM
  2. GPS issue with MediaCar
    By Jemmi in forum MediaCar
    Last Post: 08-12-2004, 03:08 PM
  3. Woooohooooo !!!!! XM Hibernate/Standby Works !
    By frodobaggins in forum FrodoPlayer
    Last Post: 07-27-2004, 10:33 AM
  4. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 05:10 PM
  5. Power Supply / Sound issue.
    By fsa3 in forum General Hardware Discussion
    Last Post: 07-10-2000, 06:56 AM
