Results 1 to 10 of 16
Thread: Car PC at my home bar???
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    I have a car pc in my car - but that is the same one I had installed in my previous car about 2-3 years ago. Haven't really kept up on current technology or software at all.
    So if I were to build a system for my home bar (rather it be compact to preserve space) what does anyone know what would be the best software out these days for that?? Also - my car has an M10000 - which was kick *** when I bought it - but now it looks like thats an obsolete board. Holy crap, I have to start all over again with my research.
    I just need capability for mp3 music and video. I still use frodoplayer in my car, but there appears to be a boatload of new software out there. Been checking out the various touch screens and I don't see Xenarc around at all. Whats up with that? My Xenarc is still going strong after 3 years.
    Has anyone done this - used a car pc at their bar to control music and video?
    cheers
    brrman
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    Mar 2006
    Colorado, but Canadian!
    There have been a few kitchenPC threads using the itx form factor. I haven't seen a bar one, but I don't see why not.
    YOu could just buy a new car system and put the old car system by the bar.
    Someone made a recipie plugin for RoadRunner so you could store all your drink mixes and such on it.
    As far as Xenarc goes, they are still around and kickin'. Lilliiputs just seem to dominate because they are cheaper. Xenarcs are still there though. In the store, on eBay, everywhere!
    1.9in x 2.9in -- 47mm x 73mm
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i'm researching an inwall design for my kitchen (you can search OT for my name and it should be at the top of the search results) I'm planning on using a cheaper screen then my xenarc because it's nto going to be abused as much as it does in the car and if something happens and wet hands touch it, it wont be as big of a financial hit when i have to replace it. I'm also sticking with the m10k because it's fine for what i need it to do. for the psu, you dont need an expensive startup/shutdown controller so you can use the 'pico' psu that is tiny and gives you 200w. i think there are others out there that you could use as well. i just have to figure out a what wahl-wart (sp?) to use to get the 12vdc to the psu.
    i'm up in the air about which front end i'm going to use, probably roadrunner because of it's vfd plugin capability. for the audiocard i'm strongly considering the modded silverstone usb dac.
    speakers... i'm thinking about using some tiny monitors (either zaph audio 3" full range or aura 2" gangbox speakers from madisound) then I'll just add a small sub (have a bunch of eu-700 6.5" subs laying around) and should have a pretty good ambient music setup (nothing that i'd crank too loudly).
    as an added feature i'm going to ad an imon vfd. this will give me a nice tactile volume knob, remote control and a cool vfd display screen as well.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    hint hint either of you...Look in my forsale thread for a cheap PSU.
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Maybe another option....
    Have you heard of the XBOX running Xbox Media Center (XBMC). It's a lot cheaper than doing a whole new computer if all you want to do is MP3, Video, Pics. http://www.xboxmediacenter.com/
    I have 2 XBOXs setup this way at home and I can stream music, movies, pictures and more from my pc to either one of them. Just giving you another option.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
    Aug 2003
    very cool guys - thanks for the info, Scott. Was pretty helpful.
    I have a powered Klipsch sound system I am going to run off this. It sounds awesome just playing off my Zen, so it should be fine off the bar-pc.
    The Xbox is a sweet idea, but I'm not a console guy at all. I am a software engineer and wanna use an actual pc to run some of my own software as well.
    I am still currently building the bar - so the pc won't happen til march or april, but I figured I'd better get my specs down.
    danke!
    B
    Apr 2007
    the coolest part of this idea is even if u dont need it id add a drink making program in
    Constant Bitrate symon_say's Avatar
    Aug 2006
    Dominican Republic
    NO men, you can put a carpc in a bar, but you can do a BarPc
    Design [000000000-]90%
    Parts [000-------]30%
    Installation[----------]0%
    Integration[000-------]30%
    Nov 2006
    Don't complicate it. Paying premium dollars for a mini-itx setup in order to save a few inches and use a little less power is silly for in-home applications. I bought my kitchen pc for dirt cheap on Craig's List. I put media center on it along with 200gb of MP3's.
    Aug 2003
    Wow - its been a year - but I thought I would update this thread I started... My BarPC is installed and works great!
    I basically used the old m10000 board with a new case and added a 15" touchscreen I got off of ebay.
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. New to CarPCs? Don't know where to start?
    By RedGTiVR6 in forum Newbie
    Last Post: 06-15-2006, 11:08 AM
  3. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  4. home pc to car pcparts
    By dc5k2os in forum Newbie
    Last Post: 11-03-2005, 07:25 PM
  5. Replies: 2
    Last Post: 10-08-2005, 04:01 PM
