Results 1 to 3 of 3
Thread: what could be causing my windows to not sut down?
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    the last two times ive used my car, windows didnt automatically shut down when i turned off my car... and it caused the battery to drain completely..
    what are some common causes for windows to hang like that? i havent changed anything since it started happening... before the past few days it had only happened like twice in the last year, but now every time i turn off my car, roadrunner is still on and music is still playing when i turn it on again...
    carputer - done.
    Feb 2006
    Vancouver, BC
    what startup/shutdown controller are you using? If it's still working when you get back then it means that there's no signal for a button press. Check your connections.
    Mar 2006
    Colorado, but Canadian!
    Or if you have it to never "pull the plug" and stay in standby or something, if a driver causes it to hang, then it wont shut off.
    Most common are driver issues. Common of those, is USB stuff.
    1.9in x 2.9in -- 47mm x 73mm
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. Ahhhhh Windows Can Blow Royally
    By Sidewalksalvage in forum Off Topic
    Last Post: 01-25-2007, 02:17 PM
  3. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
