Results 1 to 10 of 20
Thread: Attension Electronics Gurus
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    Can anyone recermend me an 8bit ADC & an 8bit shift register, I'm having alsorts of fun with my Sony joystick inferface, if your interested in what its for.
    Rob
    :edit: got ADC & DAC muddeled up, doh!
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    Rob
    Rob is offline
    Aug 2001
    Missing In Action
    Me happy, me found a chip which does what I want the 0808, click here for a circuit for it. Anyone know anything about these chips?
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Could you let the joystick emulate keystrokes on the keyboard ?
    like assign certain buttons on the keypad to the functions on the joystick ?
    I would love to use the stick with the markus zehnder plugin.
    The way I see it, is, I need 11 switches to work with this plugin.
    The joystick I have happen to have these 11 'switches'
    Greetz,
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Rob
    Rob is offline
    Aug 2001
    Missing In Action
    I was going to use it with one of the com port pluggins, there's one which allows up to 16 buttons on a single port.
    Jan 2001
    The Netherlands
    dunno if the markus zehnder plugin has an option to be controlled via the com port..
    will check it out..
    But..
    Is it possible with some chip to take the input of the joystick (analog resistor values) to turn into keystrokes.. (with the old guts of an keyboard.. the thing only has to make contact..connect the wire so that the keyb. controller thinks a key has been pressed....)
    Greetz
    Rob
    Rob is offline
    Aug 2001
    Missing In Action
    It should be possible, with a few chips, I can sketch up a block diagram now, but it'll be a while before I can get any more info, my testings no going great.
    Jan 2001
    The Netherlands
    testing no going great ? damned..
    I'll wait.. got the time..
    I figured out the Markus Zehnder Plugin can be controlled via: Keyboard, Serial Port, Parallel Port and WinLIrc
    So serial port can be done..
    however.. I have no experience in this.
    Should I wait for you to finish your testing ?
    also.. at http://llg.cubic.org/tools/sonyrm there is a schematic how to connect it to the joystickport of a computer.. but all software is in linux..
    Good luck with your testing !
    Greetz,
    Rob
    Rob is offline
    Aug 2001
    Missing In Action
    Do you have a link for Markus Zehnder Plugin, especially for the serial port interface. I've seen the Linux interface before, but as I don't have a game port or Linux it's not an option for me. Althought I contacted them a while ago and they where quite helpfull.
    Jan 2001
    The Netherlands
    http://www.markuszehnder.ch/projects/lcdplugin/
    no gameport ?
    what kind of audiocard do you have ?
    (normally these cards would have one)
    Greetz,
    Rob
    Rob is offline
    Aug 2001
    Missing In Action
    Originally posted by Raas
    no gameport ?
    As my sig says Xitel USB Audio.
    Looking at the Markus Zehnder Plugin, not 100% sure how the serial inpot works exactly, I should have some free time come the weekend so I'll have a play with it then.
