Results 1 to 8 of 8
Thread: carpc pentium 4 vs desktop duo core2
    Jan 2007
    Heya i've been reading on all the sections and learning a bunch on making a carpc. Realizing that for a quality setup its gonna cost some money I wanted to run a scenario buy all of you. I have a desktop p4 that ive been using for years. Its a 3ghz with 1gram and videocard -everything I need to run a carpc...except that its gonna run too hot and/or need alot of power. I also am in the videogames industry and it is time to buy a new machne to run this years games. Im torn between using the money to upgrade my home pc to a duo core 2 with all the necessary upgrades (motherboard, new ram, video vard and such) or buying a new low power setup for my new carpc. Besides being power hungry or hot, are there ways to overcome this if I want to use my current p4 3.ghz. From my understanding I would need a power inverter and a good quality one at that. Can I use a another battery for the cappc alone?
    Thank you for your time,
    Robert
    Jan 2007
    Straubing, Germany
    Heya Mate,
    i am not so sure on the motherboard issue, haven't been involved into it for that long. However, I am sure that you do not want to run the system of an inverter. It would introduce a lot of noise into your system and is also very inefficient. The best thing to do is to use a DC/DC power supply.
    Hope that helps a little....
    CarPC progress:
    Planning: ******** | 100%
    Hardware: *******- | 90%
    Software: ********-- | 70%
    Install: ********- | 90% (Its never really completed!)
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    you don't need lots of power in a car. If you do it right, you can strip out all the junk and run on a low power CPU.
    If you want tons of processor power but low energy usage go with that core 2 duo IN THE CAR
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    my opinion is that a PC can never be too powerfull and since you have it why buy another to use as a car pc..
    1. find your cpu's power needs.. (i am wondering how much wattage your current power supply is??)
    2. if you can keep it all under 220 watts..then buy a DSATX (expensive but worth every penny.)
    3. Avoid inverters (problematicand expensive if you want a good one..or a true SIN inverter...search for that)
    4. upgrade your home desktop..
    5. using another battery for carpc would lead you to use a battery isolator for charging both battaries..(search for that) and good ones are pricy..
    I am powering an AMD sempron 2800+ with many many many stuff connected..
    as for heat.. you can always add many fans.. i have 3 in my homemade case.. never run hot and i live in Greece..
    just my opinion..
    Constant Bitrate symon_say's Avatar
    Aug 2006
    Dominican Republic
    Quote Originally Posted by Nomader View Post
    just my opinion..
    Do you use that PSU, cause i want to make a system with that cpu???
    Mar 2006
    Detroit MI. Westside(M-39 EXIT 9)
    What he said! i ran a p4 2.8 full size compaq tower in my van for 2 or 3 weeks before i got stuff to down size the setup, your not asking for to much, but i haven't had a itx board yet that will support over a 2.8 but there are some that will do it ! i use a coleman powermate 600watt inverter and it's 2 years old and still working, so replace your D-top and use those top notch part on a killer car computer ! really you would not notice the diff in the two when intalled in a car, haven't seen any itx mb's with pci express on them and without video demand i don't think the processor will go above 60% of power draw
    Underconstruction for 2007 !!!!
    Apr 2006
    Greece
    yes i am using the DSATX..check my CarPC Specs on the left
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    People that use power inverters make no sense to me; if you think about it is a total waste of everything. Carnetix has a new PSU that should be enough to power your MB, if you need more just get a second PSU that's less expensive to run peripherals.
    08 Lincoln Navigator www.mobiteklink.com
  1. 2005 G35 Coupe Pentium M CarPC
    By Caelric in forum Show off your project
    Last Post: 02-09-2009, 09:12 PM
  2. 2005 Infiniti G35 Pentium M CarPC
    By Caelric in forum Worklogs
    Last Post: 11-24-2006, 01:16 PM
  3. PIN MOD not applicable to Intel M cpus/mobos?
    By ironic in forum General MP3Car Discussion
    Last Post: 06-13-2006, 05:36 PM
  4. AMD AM2 CPU Low Wattage
    By ACE in forum General Hardware Discussion
    Last Post: 06-11-2006, 05:13 PM
  5. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
