Results 11 to 20 of 21
Thread: INFILL G4 - Australian and New Zealand Questions Answered
  1. #11
    Mar 2007
    What's your solution for New Zealand? Does CoPilot have NZ map data?
  2. #12
    Constant Bitrate DAE51D's Avatar
    Nov 2006
    Seattle, WA
    Are there any internal PCI slots or a PCMCIA slot so I can use a PCMCIA wifi card?
    Also, it seems that mp3car.com is forcing "Street Deck" on these when they sell them this summer. Is there anywhere to get/purchase/download the "Infill Station" software that is shown in all these pictures?
  3. #13
    Sep 2006
    Sydney
    www.maxice.com.au
    Thats where i got mine.
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by DAE51D View Post
    No.
    Forcing is quite a strong word, don't you think?
    If we were to just release the G4 without an OS, users would not be able to use the features built into the G4...like FM radio, the build in amp, etc.
    Jan Bennett
  5. #15
    Constant Bitrate rotarypower101's Avatar
    Oct 2004
    Portland/MtHood Oregon
    Screen technology?
    Any improvements over the T3?
  6. #16
    Mar 2006
    Quote Originally Posted by RedGTiVR6 View Post
    No.
    Not really unless you are offering it without the SD software.
    Lee
  7. #17
    mhk
    mhk is offline
    Mar 2007
    amsterdam
    Is it true that you need to install a different soundcard in order to get an audio line-out for external amps?
    If so, how hard is it to install a different soundcard?
    Oct 2004
    Maybe there is Internal I/O SPDIF port as "VIA EPIA NX-Series Nano-ITX Mainboard" has? Can I order one from you with delivery to Europe (Lithuania)?
    Aug 2005
    the Netherlands
    Quote Originally Posted by KEMERIS View Post
    I'd like to know also if there is an spdif-out (co-axial or optical) as I have a 5.1 amp that accepts this.
    That same amp uses an remote and displays the value of the volume and settings over a composite video connector. is there a button to switch between video inputs?
  10. #20
    May 2007
    Quote Originally Posted by jabz View Post
    yeah definitely need this if it's coming to NZ, for the USB TV Tuner are you experimenting with the DVB-T tuners? because I know it's coming to NZ end of next month and it would be very handy to have, considering the stronger DVB-T signals will be getting put out compared to the current analogue low signals we have
