Results 1 to 10 of 17
Thread: Will this PC work for a car?
    Dec 2006
    Hi Guys,
    I'm new to this hobby and I been reading around a bit. Wanted to ask if this pc will work for a car. I notice that building one would cost alot. I was at compusa tha other day and i saw a acer aspire minitower which look small enought to fit under a car seat. Is there alot of moding that require if i was to purchase a pc like this that has already been built. Thanks for any input.
    Newegg.com - Acer Aspire ASL310-UD631A Core 2 Duo E6300(1.86GHz) 1GB DDR2 320GB Intel GMA 3000 Windows Vista Home Premium - Retail
    Newbie pasan's Avatar
    Mar 2007
    Sri Lanka
    Quote Originally Posted by tlr_justin View Post
    Hi Guys,
    Hmmm I think building a PC for car is more fun.
    Pasan...
    Oct 2003
    Copenhagen, Denmark
    Looks like it has a DC input of some sort, does it say on the case what input it accepts like 12V or 19Vdc or something ?
    Not doing carpc anymore
    Elsewhere
    Hi Guys,
    Understand that any PC can work in a car. Some PCs have issues that are difficult to overcome.
    As someone mentioned, it has a DC input, which would likely be served by a Carnetic PSU like the P1900. It all depends on the output voltage of the power brick:
    Remember that heat and power consumption are two factors you have to consider.
    How about the Wiki?
    Apr 2005
    Ghetto Mexico, CA ('Bolen Park')
    Hey tlr_justin, Welcome to MP3Car! Don't focus on the power hungry pc for your Carputer unless you're thinking about making it a hardcore gaming rig in your car... and if you're not worrying about a budget, because Core2Duo can set you back a few. Try a standard P4 Motherboard with a P4 1.8ghz processor. I have a MSI Socket 478 Motherboard with a 1.8ghz Processor and a Gig of ram, and it works wonders. I'm going to move this into my car soon. So don't focus on PERFORMANCE. You can find something that will run solid in your car but you dont need anything power hungry. Hope that helps and once again WELCOME to our world :-) *You'll understand once you're here for a while*
    "PEBKAC - Problem Exist's Between Keyboard and Chair"
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Read about some difficulties with Vista so do some research..
    Dec 2006
    ty guys,
    It was an example. I did read before that member suggest not have the most powerful pc in car. and i did saw a acer with the P4. just didnt know if going this way would work or do i have to built one. i built all of my home pc but never a carpc so i don't know if there were a huge difference, i figure it would be safe to ask before i act. I'm never afraid to admit that I'm stupid, it just a way for me to learn thank you very much for all the helpfull advice.
    I forgot to say that i got a 400watt inverter for advance autopart, which will be my powersource. would tat be ok for the regular power connection of this type of pc?
    Apr 2005
    Queens, New York
    It all depends on how you want the fucntionality of the carpc to be. Inverters cant be tapped into the ignition to automatically start and shut down the computer. You can buy a startup/shutdown controller or better yet get a Carnatrix PSU to power it....
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Quote Originally Posted by Cheekz185 View Post
    You can build some simple circuits to turn on an inverter/pc automatically. I don't use an inverter to power my pc any longer (onboard dc-dc instead) but I still use the inverter, and have a circuit to turn both on with the stereo.
    Edit: That said, if I were starting fresh (and didn't have 6 years of baggage) I'd go straight dc-dc for everything. Makes for a much more efficient and much cleaner install.
    -Nick
    _____________________________
    www.mp3vw.com
    Jan 2005
    I actually have an older model of this same computer, comes with a amd 64 3500+ and 512 ram but the same pretty much otherwise. i plan on using this for my carputer as well, the only real problem im having is that it gets real warm. not a problem running under regular circumstances but i figure in a car in the summer i will have issues. more then likely i will build a new case with only a slightly larger footprint in order to accomondate a fan or 2. If you live close to a circuit city they may have these open boxed which is how i bought mine with a warentee. mine cost me 350$ practically brand new before the warentee. Vista may be problematic with gps drivers and some of the programs, more then likely all the front ends actually.
  1. Car PC & Bose/Philips CCR800 Aux input
    By Gamer64 in forum Car Audio
    Last Post: 01-25-2007, 04:13 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  3. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  4. New toys for the pc car
    By gizmomkr in forum General Hardware Discussion
    Last Post: 02-06-2002, 05:55 PM
