Change COM port assignments in the Device Manager.
I have my GPS on COM5, I believe it is (BU-353) and have Xport forwarding it to COM10, and have Centrafuse setup correctly to see it. I have my USB Bluetooth dongle connected, and it's on COM3, I believe (doesn't matter that much which COM). Whenever I enable my phone's (Motorola E815) Bluetooth, it interferes with my GPS (sometimes it doesn't connect to any satellites, sometimes it goes on and off), and I notice the phone beeps a lot indicating that the computer is communicating with it. I don't think a COM port change for the Bluetooth or GPS would help (maybe?), what else can I do to have both my phone and GPS connected to my 'puter?
Carputer Progress:
Re-do fabrication of screen [DONE]
Add mini-USB and micro-USB power from M2-ATX [DONE]
Teardown PC [100%]
Add HDMI > VGA converter [0%]
I thought about that and not sure if that will matter because the port for GPS is COM10 and the Bluetooth is on COM3 or something lower like that. What port would I change it to?
Carputer Progress:
Teardown PC [100%]
Is your GPS and BT dongle on the same USB hub?
I just thought about this as possibly being a problem. I think I have something like 6 USB devices connected using 2 hubs - one plugged into the other. First, would having one hub plugged into the other create issues I would worry about? Second, I guess I could do some math and figure out how much power I'm using with all these devices and see if my M2-ATX gives me enough.
BTW, my GPS is plugged into one of my onboard USB ports, not either hub, but the Bluetooth dongle is plugged into one of the hubs.
Carputer Progress:
Teardown PC [100%]
Is xport forwarding to any other ports?
