Results 1 to 3 of 3
Thread: Cheap Laptop...run google Earth?
    Mar 2007
    KC, MO
    SO, Is there a way to run Google Earth on a machine with lower resolution than 1024x768? I have an old laptop and 800x600 is max. I am getting errors when I try to run it.
    Any work arounds?
    Thanks guys!
    Mar 2006
    Colorado, but Canadian!
    i think it has more to do with the video card then the resolution.
    what errors do you get? are you sure they are specific to resolution errors?
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    KC, MO
    Thanks 2K...It tells me it needs 1024x768, it says it will run better with this resolution, but it will try to run. It recommends I upgrade my graphics card and then tells me to try open GL mode. When I try to open open GL code, it tells me to try directx...then back to the open GL mode...
