Check this thread out. It sounds like it's what you're looking for.
*Edit* Actually I don't think that is it. There was one I saw a little while ago that did exactly what you're looking for, but I can't find it. I'll have another look around.
Im not sure where this would fall, but I was wondering if anybody has made or knows where you can get a digital video application that would stamp GPS location on a video.
I offroad a lot and I thought it would be nice to start a record and store on my PC and when later reviewing the footage I could note the cordinates and add them to my GPS mapping software so I could find the location later. Sure I could just note locations as I find them, but when your climbing over rocks and trying to watch the road sometimes its often to dangerous depending where you are to play with a computer screen.
Anyways thanks for reading.
I installed my carpc into my pet Kangaroo, mate.
Are you using a camcorder mounted in your vehicle to capture video? If so, you could use a bullet camera and insert your GPS data on it and record that to the camcorder. What kind of GPS info are you wanting to record?
Is this what you are looking for except having GPS data instead of bike data superimposed on video data?
http://media.putfile.com/DataAcq
Hi there,
I have a lot of experience in the GIS/Software engineering industry and I think possibly viewing this problem from the wrong angle,
Instead of using video overlay hardware, you should perhaps be recording your journey using the GPS (create a trip log - a shape file with all track points) and then relating that to the video.
Cheers,
Kiwi.
Hi,
It is possible to put all the pertinent GPS info on the video data logger screen and at the same time write a SD card log file which could later be viewed in Google Earth. The logger could have a button that when pressed would tag the lat, long, time as "placemark" when displayed in Google Earth.
Here's a Google Earth file attachement from a GPS running at 4 samples per second. You have to change the file extension from ".txt" to ".kml" Then if you have Google Earth installed on your machine, just double click on the file and it should bring it up automatically. The vertical lines indicate the .25 second interval data rate.
Actually believe it or not, but thats the thread that got me thinking. I do want it to capture digital footage and store on my pc. I was hoping if there was an app like it or a way to work with it to either stamp the location on the video or I suppose if needed it could take a location a write to a separate file, but the times would have to correspond perfectly to make sure the location would be easily identified from the video so the GPS location could be found later.
I thought about using Webtracker one of the apps in the software section, but Im not really looking for google map support, but however it would give me a way to track lat/long every so many seconds or minutes without having to manual hit a track button.
Kizer, I'm not using a PC to capture the GPS data, however, you could write a relatively simple program using Visual Basic to read GPS data from the PCs serial port and write a plain old text file that can be easily imported into Google Earth. If you get a sensitive GPS unit, tree coverage could be mitigated or using a dead reckoning GPS unit will work if you are not bouncing around too much in your car.
What I am building is a datalogger the overlays GPS data at 4 sample per second on video from a small bullet camera. The logger can also write this data to a 2GB SD card in a file format directly importable to Google Earth (the file attached above). It also has the capability to plot the path on the video screen. This will fit in a fanny pack along with a small camcorder (for recording the video) and the bullet camera which is velcroed to my helmet. It's my personal data acquistion unit that can be used on hikes, bike rides or at the race track. I'll try to attach the video from the logger next time.
