Delorme Streetatlas and the GPS Tab window size
Okay so the GPS Tab window size can not be increased like the other tabs... Why? Does anyone know of a hack that will allow you to increase the window size of the GPS tab?
Becuase I have to run in 640x600 (Datalux touch screen) I can't see the lower portion of the GPS tab (like the heading and the last two options in the setting and the "Sat Info" button.
If I could only increase the size of this window by just a couple of pixels I just might be able to see everything.
The other tab's you can increase the window size without limits..
Any idea's?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
