There needs to be some
software to create a virtual com port so
iGuidance (and most other programs) can use a USB
GPS receiver. If you don't like the one you downloaded, then look for the CD than came with the receiver when you first bough it. There must be the driver on it. With DeLorme USB GPS, if I'm correct, when you start installing it, it should ask you if you plan on using it only with DeLorme software, or if you need it for 3rd party software programs, too. Choose the driver for 3rd party programs.
(All this will work in the new iG4 the same as in your old iG2)
