View Poll Results: Which route option do you use?
Voters
15. You may not vote on this poll
  • Quickest
    14 93.33%
  • Major
    0 0%
  • Shortest
    1 6.67%
  • Local
    0 0%
Results 1 to 7 of 7
Thread: Which Route Option do you use in iGuidance?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Just curious.
    What do you have your route options set as in iGuidance and why? I noticed that some route options give less direction errors in certain situations. I am currently using "shortest route" to save gas, but it doesnt always seem the most accurate. Using the "shortest route," my drive to school everyday is 15km instead of 16km (fastest route). Do you guys think using the shortest route is worth the savings? For my case, the shortest route option takes me through a community with tons of school and playground zones (but I only have to slow down when returning home because those zones are not in affect in the morning). Opinions welcome.
    Newbie kizer's Avatar
    May 2007
    Marysville, North of Seattle WA
    I just have it set to the default. Isn't the default the shortest?
    FLAC Marvin Hlavac's Avatar
    May 2005
    The default setting in iGuidance is Quickest. This is the only setting I trust. iGuidance generates quite good routes, but in my experience only when the Quickest setting is selected.
    The Shortest may occasionally help on a very short trip. But make sure you zoom-out, to check if the plotted route is really how you wish to travel.
    The Local and Major DO NOT work as advertised - at least not in my city. Be very careful when you use either of the two settings, because the route generated may be quite bizarre - adding miles and miles to your trip.
    * Quickest = good
    * Shortest, Major, Local = use with extreme caution
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Quickest
    Shortest tends to make my trip longer by forcing me to go on slower roads. Because of this you end up wasting more gas.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    i use quickest most of the time.
    on the rare occasions when i need only local streets, i set it to local, if it tells me to get on a freeway, i either set it to avoid that road, or keep going and have it redirect me.
    for example, when i broke my shock offroading, i had no option but to drive a short stretch of highway until i could get onto old route 66. from then on the computer guided me back correctly on local streets. what on the freeway would have taken me no more than 30 minutes took me 2 hours surface street, but saved me in replacing more components than necessary.
    local has worked in several instances for me, every time i have used it, never failed me. YMMV
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Mar 2006
    Colorado, but Canadian!
    I use shortest but the town isnt so big. I dont go cross town. So for my 20-40 minute drives, with shortest I avoid most of the stop lights, and instead get stop signs. More turns and such, but for me ends up faster because I dont have to wait for the stop lights, just my turn at the sign. However if I am going a fair distance then I set to quickest.
    1.9in x 2.9in -- 47mm x 73mm
    May 2007
    Marvin,
    I use the Quickest.
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Support for UK iGuidance (PrymeNav)?
    By aiml27 in forum Mobile Impact
    Last Post: 03-30-2007, 03:09 PM
  3. Iguidance and Centrafuse?
    By thrmaln in forum Centrafuse
    Last Post: 03-03-2006, 08:24 PM
  4. How to make Frodo's RoutisLauncher work with iGuidance
    By dodgetimes2 in forum Software & Software Development
    Last Post: 09-10-2005, 02:47 PM
  5. iGuidance window focus problem?
    By Talon in forum Centrafuse
    Last Post: 02-03-2005, 02:38 AM
