Results 1 to 10 of 11
Thread: iG 3.0 Crashes When Driving Through Tree Shaded Areas?
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    I've noticed this since I upgraded to iG 3.0 over a year ago now. I didn't uninstall 2.1.3 before the upgrade, just installed 3.0 over it. Never had a single issue with 2.1.3 but for some reason 3.0 has always been iffy.
    I can usually recreate it by driving through any area where there a lot of trees surrounding the road.
    I am using a Holux GR-213. But as I mentioned, iG 2 worked fine.
    Jul 2007
    When you look at the GPS info in IG is it losing all the satellites?
    Feb 2005
    Haven't checked. But would that still cause it to crash?
    Jul 2007
    I'm just asking questions. I haven't had that problem. Does it give you an error? My GPS just has lots of trouble picking up signal in wooded areas but IG hasn't crashed on me yet.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by LiquidKernel View Post
    Mine would do that too, but only in 3d mode. I switch to 2d when it happens and it works fine until I get out of the area then I put it back. Hope this helps.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Feb 2005
    Quote Originally Posted by fixerofallthing View Post
    Interesting theory. I'll check next time I drive and see if that's causing it. Perhaps 4.0 might cure it?
    Feb 2005
    I tried out your method and it worked. But I think that's a poor solution and not sure why iG does this in the first place. Does 4.0 fix this by any chance? I'd upgrade if it does.
    Just for reference, here is my setup (it might have something to do with it, I suppose):
    Holux GR-213 behind glass
    Win XP Pro stripped w/ nLite
    Latest RoadRunner w/ iDrive theme
    Feb 2005
    Finally got iG 4.0 and it solved the problem and added cool new features Love how it re-routes without flashing the screen.
    Low Bitrate scottgs's Avatar
    Feb 2006
    Knoxville, TN
    Does it sill flash when it goes to the "guidance" screen? I think that's what it's called, the screen it switches to when you near a turn.
    Feb 2005
    I actually turned off the guidance screen because it looks a bit tacky in the iDrive theme I use. I'll try and let you know.
  1. ig 3.0 on PPC
    By Cheekz185 in forum GPS
    Last Post: 05-07-2007, 05:40 PM
  2. Good news to IG 3.0 users! and IG 2.0
    By mbkowns in forum Centrafuse
    Last Post: 08-11-2006, 08:24 AM
