Ah well, VGA uses RGB but if your monitor is a true RGB, then what you want is to do is convert this:BUGBYTE- your link is not to a RCA to RGB adapter. it is for a RCA to Vga. they are totaly different. i still stand by my statement there is no such thing. but thanks anyways.![]()
to this:
In which case you can use this device to do it.
Perhaps my use of the term adaptor suggested that there is a magic cable to do this. You are correct that there is not. However, that does not mean it cannot be done. There is almost always a solution for something like this.
LinkBack URL
About LinkBacks
