Results 1 to 10 of 15
Thread: Need Help! Stomped Everyone I've Asked!
    Aug 2007
    MARYLAND
    I Am Trying To Connect A Garmin Gvn 52 Which Has A Rca Video And Audio Output To A Mediaview Rearview Lcd Mirror Which Has A 20 Pin Molex Male Rgb Input. The Damn Rearview Mirro Is From China So Tech Help Is A Deadend. Trying To Find Out If Garmin Has A Rgb Adaptor. Doesn't Look Good. Pioneer Uses A 20 Pin Rgb Cable For Their Navigation But I'm Not Sure If It Will Plug And Play With The Mirror. Mediaview Advertizes The Mirror As Having A Navigation Input But Doesn't Say What System It's Compatable With! Auwg!
    I Think I Made A Mistake Buying This Mirror. But It Has Temp And Compass Also And I Haven't Been Able To Find All Three Options In A Mirror. Any Ideas Anyone? Help!
    Elsewhere
    First of all, the all-caps typing is parsed to this ugliness. Please stop it.
    Second of all, the focus of these forums is on installing a PC in your ride. The GPS forum deals primarily with GPS hardware/software for the PC.
    You may be able to get an answer to your issue here, but you're more likely to get an answer from the manufacturer or from another GPS-dedicated forum like gpspassion.com or somesuch.
    Good luck.
    How about the Wiki?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Find the pin outs of the 20 pin mirror. Buy an RCA-RGB adaptor. Build a cable between the two.
    That ought to fix it.
    Want to:
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Looking at www.mediaviewtech.com there are several different models. The one that seems to match your description is described as having multiple camera inputs. These will be RCA compatible...but unless your screen came with a manual or tech sheet describing the inputs you'll have a hell of a time figuring out what wires to use. If you can't get a description from the seller, send it back.
    Aug 2007
    MARYLAND
    first of all darquepervert, my caps lock was broken on the computer i was using but hey, since you put it so nicely, NOT! i will use another computer since capital letters seem to annoy you. second, i believe my issue is suitable for this forum since it deals with gps hardware. if you can't help me, then don't post.
    the manufacturer is in china and i don't speak chinese. their distributer could care less because i am not their customer. they sell to online electronics outlets. i contacted the online store where i purchased the item and they had zero tech support. garmin was a joke. i knew more about their products than their operators did.
    BUGBYTE: thanks for the suggestion but there is no such thing as a rca to rgb adapter. rca and rgb are two different languages. i have found a converter box which converts rca comp. to rgb data but no audio and you have to slice and and solder sync wires.i just have a hard time believing the manufactures of this mirror expected novice car owners to slice and dice cables in hopes that they might fall on the right combo of wires.
    as i have been told a rgb cable is a data cable for giving and receiving information. (like a touch screen) rca is just for audio and video output.
    PIP: tryed the multiple camera outputs, unfortunately they reverse the image on the display. everything is backwards. and you have to have the car in reverse or a turn signal on to activate the video input. i could trick the mirror into thinking the car was in reverse but the nav would be on all the time.
    Aug 2007
    MARYLAND
    UPDATE~ i have struck paydirt. i found out that the mirror/lcd/compass/temp device i purchased was only designed to work with a nav unit made by VDO DAYTON INC. these nav units are mainly sold in europe. i found that is does have maps for the USA and i've been told its a very nice system. i know pioneer uses a twenty pin molex cable also but don't know if its compatable. looks like i'll be shelling out $900.00 for a VDO. oh well. thanks for the help everyone. i would say don't buy products from china but that would include almost everything electronic out there!
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Wow.... Yelling at a mod.... that's smart.....
    Rafster
    Elsewhere
    Quote Originally Posted by JUSTHAVNFUN View Post
    I stated facts.
    It's not that capital letters annoy me. I use them all the time, just not in en masse.
    The fact is, when you type in all caps in this forum, it parses it so that each word is capitalized. It loks ugly and is difficult to read. Don't believe me? Go look at your own post!
    And you completely missed my point somehow.
    The mp3car.com forums are all about installing computers in our vehicles. That's not to say that someone can't help you here or that it's inappropriate. It's simply less likely to get you any assistance with your issue. If you interpreted my reply as one saying you're not welcome, then I apologize for giving you that impression.
    The fact is, you're wanting assistance with non-PC GPS hardware. Considering the focus of the mp3car.com forums, you tell us whether this was the best choice as far as where you'll get assistance.
    Never mind. You proved my point for me.
    Glad you got it sorted out. Sorry that it's gonna run you $900 to get it working. That's a big chunk of cheddar.
    How about the Wiki?
    Aug 2006
    Central PA
    You may want to read your threat titles more carefully as well. All the people you "Stomped" must be upset .
    All in fun.. Anyway, glad to hear you sorted things out.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I see. Well, make sure you let these guys know about that: Video to VGA adaptor-converter
    For $900 plus the $100 you spent on your mirror thing, I'll sell you a complete car PC system with a 7 inch touchscreen...
    Want to:
  1. This may be the dumbest thing anyone has ever asked
    By MikGan in forum General Hardware Discussion
    Last Post: 04-14-2009, 05:09 AM
  2. Replies: 5
    Last Post: 03-15-2006, 10:02 AM
  3. i know its been asked before
    By j03y in forum LCD/Display
    Last Post: 01-15-2006, 12:11 AM
  4. Which LCD is best? (I know it's been asked a lot...)
    By temple2101 in forum LCD/Display
    Last Post: 08-02-2005, 11:59 PM
  5. Probably asked already power issue...
    By Krait in forum Newbie
    Last Post: 05-26-2005, 09:12 PM
