Results 1 to 7 of 7
Thread: gps USB or SERIAL?
    Constant Bitrate xpluis's Avatar
    Sep 2006
    Mexico City
    gps USB or SERIAL?
    What is better, a USB gps, or SERIAL gps??
    The Bu-353 USB stop work some times after hibernation, i need restart my pc for get the correct sats again. What about serial gps? is better?
    Aug 2007
    i think the usb is better, but not sure, usb is a better and newer technic
    Jun 2002
    Virginia
    Quote Originally Posted by xpluis View Post
    I've been using the BU-353 for years and it has never not come out of hibernation. Make sure it's plugged into a USB port on the computer rather than a hub.
    Aug 2007
    Side note usb signal looses strength the longer the wire, serial does not suffer as much from this. Also most GPS seem to work better plugged into a primary (on the MB) slot inorder to get full power usage.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    For anything else, USB will be easier. For GPS with current update rate, serial is much better. With serial, no suffering from hibernation problem, no additional driver needed. The only draw back of serial is you have to find a way to power the device as most of them isnt' getting power from serial port.
    Current USB do need be bridge/convert to serial for 3rd party apps and that what the driver is doing.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Maximum Bitrate DeltaFX's Avatar
    France
    On some industrial motherboards, the serial port has its own powerline, sometimes you can even choose if you want it to be 12v or 5v
    Now Galileo is real. Muhahahahaha :p
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by MatrixPC View Post
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  1. Problem with USB to serial converter
    By openminds in forum GPS
    Last Post: 07-29-2011, 12:32 AM
  2. Replies: 4
    Last Post: 10-06-2006, 08:36 AM
  3. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  4. USB vs Serial GPS?
    By drPheta in forum GPS
    Last Post: 08-22-2006, 05:02 PM
  5. WTT: Bluetooth GPS for USB GPS
    By arebelspy in forum Classified Archive
    Last Post: 09-29-2005, 12:53 PM
