Results 1 to 10 of 13
Thread: winamp plugin -> gps data on char lcd
    May 2002
    Sef'Kylar
    Anybody think they can make a winamp plugin to output gps data to the character lcd? I think if you have an nmea antenae you may be able to do it.
    How about a standalone application to output stuff like time, location, speed, elevation etc.
    I know you can do it!! have at it!
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    moahdib's Avatar
    Jul 2000
    i have an app that I hacked it sorta but it's called GPSthing.
    I got the source code and messed around a bit to output Heading ( N,NE,E,SE,E etc..), Speed, Altitude, and # of sat tracking.
    The CPU and PC temperature you see is just from MBM5 using an OSD. I was too lazy to figure out how to hardcode it into the app since im not a C++ programmer.
    Here is the link to the program: http://www.coastnet.com/~jas/gpsthing.html
    and here is my screenshot of it.
    I can post a link to download my hacked version of it but you HAVE to use it at 800x600 res. or it won't come out right. Let me know if you want my hacked version as well.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    May 2002
    Sef'Kylar
    That's pretty cool actually!! but what i really had in mind was for character lcd. Next week I'm going to start reworking my software, unless i find something totally new that works for my purpose
    aka Kumaneko
    Variable Bitrate felix99's Avatar
    Apr 2002
    Europe
    Hi,
    to make it short - I'm interested
    Regards
    Felix
    P.S: would it work with an USB GPS receiver ?
    ( actually don#t have a GPS receiver but I began collecting the soft )
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc::
    ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
    Dec 1999
    Austin, TX
    I've created a java program which uses GPS data to control winamp. It also displays the GPS data and some other information in a window.
    You're welcome to adapt the source code to output to a char lcd if you can.
    Here's the link:
    http://home.austin.rr.com/sshipman/l...re/mp3gps.html
    moahdib's Avatar
    Jul 2000
    Hey Loreley> ur site has all the links but the one on the winamp java plugin doesn't work. Can u repost it for me to download and try it out?
    thanks
    My TL CarPC ver2
    Dec 1999
    Austin, TX
    oh, that's right, whatshisname jwilliams moved his site. I should have a version of his plugin sitting around somewhere I can put up there. It'll be a while before I can update the site though. Should be done by the weekend.
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    It would be no problem to output the information the the character lcd - started writing my own winamp plugin at one point, so it shouldnt be too much trouble. The only problem, is that I do not know how to get it to share the screen with another program (winamp lcd plugin). If you want JUST the gps data, that should be no big deal at all.
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    May 2002
    Sef'Kylar
    I haven't tried it yet.. But my plans were on having 2 lcds.. one for the player and one to replace my clock I have a usb/serial/parallel hub.. someone told me they are using the same thing and it works perfectly for it.. although from what I've read other wise it might not work.
    aka Kumaneko
    moahdib's Avatar
    Jul 2000
    THere is a great app that could be hacked to display GPS data and winamp data at same time if you know C++, the markus zendher plugin ( URL in my page under software).
    I will eventually try this someday, but since I have both a LCD and a char LCD screen, I hardly look at my char LCD screen to attempt this, nevertheless it would be cool.
    My TL CarPC ver2
