Any takers ? As an added element I'm based in Europe and I was using the Italy map.
Thanks.
Hi, all.
I'm evaluating the Centrafuse (v1.12) front end with the integrated Destinator navi engine. I've inserted a local map (version 6) just to test the navigator functionalities but when I try to plan a trip to a distant place (which is inside the map, anyway) the software does not make use of the highways: it insists on using normal roads. This happens both with the "quickest" and "shortest" route setting.
Anyone had ever have similar problems?
Thanks.
Thanks.
Mine does the opposit, it only wants to stay on highways or bigger roads
Using -06 map, Swe/Nor/Den/Fin..
Cool! Maybe we should mix our software configuration...
Cheers.
