Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 48
Thread: iGuidance Hacks
  1. #31
    Nov 2006
    Huntsville, AL
    Hi All,
    Even more locations added for your modding pleasure.
    I think I've got all the OSK functions except for the edit box. Seriously, any help with that one would be greatly appreciated.
    Also, anyone who wants to help out. I'm currently going through all addresses with a byte sequence of "68 FF FF FF 00". Most of these should be a white color of some sort. I've currently left off at "0x65430". There are 72 locations left with these bytes.
    Thanks,
    pb
  2. #32
    Raw Wave justintime's Avatar
    Apr 2005
    Good job! Been changing tons of text after reading your findings.
    One I have not found is the text for the headers in:
    Settings > Display Options
    and
    Settings > Route Options.
    The headers are black, and say things like:
    Orientation, Day/Night, POI Icons, Color, 3D view
    and
    Method, Ferries, Toll Roads, Carpool, Turns
    I tried locating these, but no luck
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  3. #33
    Apr 2005
    Also, is there any way to change the color of the button's text when the buttons are depressed? I deally, I would like to be able to change the color from white to black (only while they are depressed, or 'button down' state).
    Changing the buttons background color would be nice too, although Im unsure whether you already found that one. I couldn't find it. Currently looks like they are some sort of 'off white blueish'.
    2002 Honda CR-V
  4. #34
    Apr 2005
    Queens, New York
    Any1 have any screenshots of what u changed?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  5. #35
    Nov 2006
    Huntsville, AL
    Hi JIT,
    I haven't yet found any of the black text. Either the black colors are hidden deep in the resource segment, or (more likely) the color is being referenced as a single byte. For instance, take a look at some of the "6A 00" codes. Most of these are essentially pushing the value of zero into a DWORD sized register. So, "6A 00" is putting "00 00 00 00" at the top of the stack.
    If this is the case, then it will be pretty difficult to even locate the black color values. Then, once located, there will only be a limited number of colors that it can be changed to, since we can't insert a full RGB DWORD without corrupting the offsets after the insertion.
    I haven't seen anything regarding button down state, except in the "ABC"/"123" button of the OSK's.
    The button background color is actually the background color of the entire window in most cases. Check "0x19D89" and see if that works for you. In the OSK's, I have it labeled as "Top Area Background", or something similar.
    pb
  6. #36
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    This is a great thread, I think I was reading some of your work on gpspassion.com
    I just got iGuidance 4.0 will these still work? Id really like to change my nighttime background color from pure black to a dark grey.
    And I would also like to 'thin' the road lines, they are too fat and dont really re-scale when zooming in and out... ?
    Any ideas? Ive never ran a program through a text editor (or it has been a LONG time since I have).
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
  7. #37
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    You don't need a hex editor to change background colors or road colors or the width of the street borders. All you need is the THEME.ini file. There you can change all the colors you want. Here is one. Extract the file and place it into C:\Program Files\iNav\iGuidance
    Attached Files Attached Files
  8. #38
    Feb 2004
    Florida
    Quote Originally Posted by MGD View Post
    That is great.... Im going to have a lot of questions, I hope you dont mind. Ialso tried to get to the iNavCorp support site to see if they had any info, but I forgot my registration info at home...
    First questions, can you explain the 5 groupings of numbers here? And the day map road pen color. So I am assuming this is the color of the street lines in 'day' mode? But why the 5 different color sets?
    Thanks again@!
    Code:
    ; day map road pen color FC1-2-3-4-5
    ; to use same colors for all zoom levels only specify DMRPC(max)
    DMRPC0=242,0,8 242,0,8 230,143,38 117,88,75 175,147,133
    '02 GTI
  9. #39
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    Those are colors for the different zoom levels. I don't know why 5 colors but play with them and see what changed.
  10. #40
    Feb 2004
    Florida
    Yeah thats what I thought, but Ive been reading about how Iguidance 4.0 has 12 zoom levels and iGuidance 3.0 has 11... Thats why having 5 colors kind of threw me... I'll play with it though. I just try to figure as much out as I can before I have to tinker on that tiny 7in screen in my car.
    Thanks again
    '02 GTI
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  3. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  4. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  5. 25 lost hacks
    By P3rv3rt B3ar in forum General MP3Car Discussion
    Last Post: 10-25-2005, 01:34 PM
