Results 1 to 5 of 5
Thread: How to get cf gps receiver to work in car
    May 2007
    Hello all I will get straight to the skinny I have a holux gr-271 compact flash gps receiver, my cpu set up is this http://store.mo-co-so.com/complete-c...c7-cpu-p-5.htm
    I really dont want to spend more $$$$ on a gps receiver when I already have one so what i am asking is there a way to hook this in to a usb slot I thought of using a cf card adapter but not sure if that will send a signal through the usb port can this be done. thanx to all that answer.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Most CF accessories other than flash memory were made for Pocket PC's. Usually there aren't any drivers for windowsXP for these types of devices. It isn't likely that you will get it to work. You should check the CF card manufacturer's web site to see what drivers are available.
    ~Jimmy
    May 2007
    thanx for the input jimmyfitz the cf gps card that i have does come with winxp drivers so thats not a problem.
    Nov 2005
    Austin, Texas
    Your next hurdle then is finding a CF adapter that is designed to do more than just read flash memory cards. The common adapters go from IDE-->CF, SATA-->CF, and USB-->CF. Good luck and let us know what you find that works.
    ~Jimmy
    May 2007
    I sure will I am waiting for an email back from the manufacturer of my receiver as soon as I know I will let the forums know its only common courteously someone else may neen the info thanx to all.
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  2. Replies: 10
    Last Post: 03-19-2006, 04:37 PM
  3. GlobalSat BT-338 Review
    By tom2112 in forum The Review Palace
    Last Post: 06-27-2005, 12:02 PM
  4. i have a cf gps receiver
    By ombastic in forum GPS
    Last Post: 07-08-2004, 03:34 PM
