Results 1 to 10 of 13
Thread: gps loosing signal at gas station
    Low Bitrate erricson_nguyen's Avatar
    Feb 2007
    LA ca
    every time i stop for gas my gps loosing signal i checked b4 stop 4 gas at least there were 7/10 sat, any 1 have similar problem please help this newbie how to fix it i use MS usb reciever i believe it's a Pharos gps 500 Sirf III iguidance 4.0 i place it on dashboard , to get signal back i have to restart pc exit iguidance relaunch won't help
    thank in advance
    Apr 2007
    Moscow, Russia
    Are you sure the gas station does not have a metal roof?
    Feb 2007
    LA ca
    Quote Originally Posted by Marassa View Post
    i have no idea but i went 5 different station same thing happened
    Simple fix really.....don't go to a gas station :P
    The gas station will have somesort of a roof, which will block the signal from getting through, you could hack the GPS and fit a stronger aerial onto it.
    GPS works by time. All the sattelites have a precise time, which they broadcast. The GPS receiver than works out where the satelites are judging by the time. GPS microwave signals take time to reach the ground, I can't be bothered working out the exact time, but the further away a satelite is, the longer the signal takes to reach you.
    For example, if you have four satelites, each one will give a slightly different time down to the nanosecond, whch the GPS receiver can then work out where you are! With a roof, those times can get a little skewed and you'll have "lost signal" while in all reality, you won't have lost the signal completely, the GPS receiver will get widely varied times, so the GPS receiver cannot pinpoint your location.
    At any one time, there are always three or more GPS satelites above us ;-)
    With the launch of the European GPS satelites, we will actually be able to accurately work out where we are....to a meter!! Currently, US GPS sattelites can work out only to 10 meter range.
    Try to use a petrol pump near the edge of the forecourt, which should help you with your signals
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    I think you're all missing the point! When he drives out of the gas station he should get the signal back in seconds, not have to restart the pc.
    Banned
    Sep 2007
    I think it's normal, sometimes it also happened to me
    Feb 2007
    LA ca
    i dont think metal roof is the only cause the signal lost, there maybe something els
    while im listening an AM radio with clear n clean reception then there're a tromendous amount of interference when approaching any gas station, i think this might also effect
    and cause the gps signal lost, just my though
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by Laidback View Post
    the gps reciever should reaquire satellites within a few seconds...?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    personal experience pharos gps = garbage. I had two.. neither lasted a year after purchase. Got a BU-353.. its on my roof and rock solid no matter where i am.
    Live mp3Car Facebook Chat
    Jun 2002
    Virginia
    +1 on BU-353. My BU-353 is in my trunk, covered by a closed metal trunk lid, and it's still rock solid no matter where I am.
  1. using OEM GPS signal for carpc
    By met152 in forum GPS
    Last Post: 11-01-2006, 07:34 AM
  2. Cant get good GPS signal in car.
    By Ricky327 in forum GPS
    Last Post: 01-29-2004, 10:28 PM
  3. Replies: 16
    Last Post: 01-16-2004, 11:02 PM
  4. GPS signal strength - Haicom 202 GPS
    By ChrisC in forum GPS
    Last Post: 01-12-2004, 07:33 AM
  5. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
