As long as the gps unit you get supports nmea 2.0, then it will work with Streets & Trips.
As for hardware, theres alot of specific ones you can get that have usb plugs on them, for direct comptuer connections. But you need to add in shipping, and usually convert from $USD, which makes them expensive.
What im considering doing is just buying the cheapest one from canadian tire, then getting the comptuer link for it, and it should come out to about the same as a usb based one, but then ill have a stand-alone gps if i want.
LinkBack URL
About LinkBacks
